Hey, I have an '81 with an oil temp gauge in leu of the clock. The temp reading doesn't appear to move much once the engine starts. What are some numbers that the oil temp should be reading? Thanks.
it does take a long time to warm up .try cleaning the connections on the sending unit.you might even take out the sending unit and check for a build up of dirt or sludge .
I have the 81 oil temp gauge and sending unit in the stock location above the oil filter and around town on a 75 degree day the gauge reads about 160-170, just before the first hash mark on the gauge. 80-90 degree day at 70-80 mph the gauge reads right at the 12 o'clock mark, 250!
Thanks, I will do like you suggest and remove it and clean in.
