Bouncing Tach.. need help!
Old Apr 21, 2002 | 06:06 PM
KorbenDallas's Avatar
KorbenDallas
Default Bouncing Tach.. need help!
My tach started to bounce today. When idle it's fine, but when driving down the road.. 2500+ rpm.. it will bounce from side to side like a pendulum and then return to the right RPM. It's almost like someone flicked it (or thumped it) with their finger. It always goes to the right first, then back down, then it evens out at the right RPM. Once it settles down, it takes about 1 second for it to do it again.
Any suggestions?
Old Apr 21, 2002 | 07:45 PM
Gordonm's Avatar
Gordonm
Default Re: Bouncing Tach.. need help! (trw)
I assume it is for the 81 which is electronic. The only thing I can think of is a short in the board or a short in the wire form the dist.
Old Apr 21, 2002 | 07:54 PM
KorbenDallas
Default Re: Bouncing Tach.. need help! (Gordonm)
[Modified by FroDaddy, 7:36 PM 4/21/2002]
Old Apr 21, 2002 | 08:19 PM
silver 80's Avatar
silver 80
Default Re: Bouncing Tach.. need help! (FroDaddy)
tach filter?
should be down by the dist. little round thing about 1 inch long. :confused:
Old Apr 21, 2002 | 08:38 PM
KorbenDallas
Default Re: Bouncing Tach.. need help! (silver 80)
tach filter?
It's the needle that's "bouncing" while driving down the road. Is there something I need to be concerned about with the tach filter?
Old Apr 22, 2002 | 01:38 AM
Ben Taylor's Avatar
Ben Taylor
Your tach filter is busted, you can either remove it, and get slightly jumpy readings, or you will have to make a new one, here's a post with the wiring diagrams.
http://forums.corvetteforum.com/zerothread?id=136220
Look at Smokehouse69's reply.
To Bouncing Tach.. need help!
