Hugger Headers
Old May 23, 2011 | 10:47 AM
Mark Hawkins's Avatar
Mark Hawkins
Default Hugger Headers
Any Pros or Cons on Hugger Headers? I have an 81 was just looking to see what's out there as far as headers go. Thanks.
Old May 24, 2011 | 06:02 PM
KevinK's Avatar
KevinK
Pros - they let you lower the car farther, over many full length headers, if that's an issue with you. They cost less, generally. If you have space issues, they fit easily.
Cons - Less hp, and they tend to sit REAL FFFING close to the spark plugs and their wires. As in, you will likely have heat issues. Ask me how I know.
Old May 24, 2011 | 09:00 PM
imariver's Avatar
imariver
The market is flooded with cheap headers, both long tube and shorties. Be carefull what brand you buy and make sure that they apply to the type of driving you do. Most shorties and or huggers will require some modifications to the rest of the exhaust system. The only ones that I'm aware of that DO NOT require any modifications are the "McJacks"
They are a direct replacement for the ramhorn manifolds. I'm awaiting my set from McJacks now and hope to have them on this weekend.
Old May 24, 2011 | 10:23 PM
Mark Hawkins
ugh, I assume you have/had some? Thanks.
Old May 24, 2011 | 10:26 PM
Mark Hawkins
If you don't mind, let me know how they do. Total sound levels prior to and after installation of the header if you currently have the stock manifold and performance. Thanks.
To Hugger Headers
