Front Brake Issue
Old May 24, 2011 | 04:41 PM
Drawmain's Avatar
Drawmain
Default Front Brake Issue
Just replaced front bearings in my 82. When I removed the calipers, I made sure that I kept the pads open by inserting a socket between them as I pulled the caliper off. Now that I have the caliper back on, the wheel will not turn without considerable force once the caliper is torqued in place. I can move the inboard pad, but the outboard is all the way out already, so I don't believe its a frozen caliper. I finger threaded the bolts in, so I know they are in correctly, and the wheel would turn before without having to resort to using a pry bar wedged in the studs. Any ideas or should I just get a new caliper? Passenger side is the problem, no issues with the driver's side at all.
Old May 24, 2011 | 04:47 PM
...Roger...'s Avatar
...Roger...
Sounds like you didn't get the inner bearing seated correctly.
You also could have a bad hose.
Old May 24, 2011 | 04:49 PM
Drawmain's Avatar
Drawmain
You know, that may well be, how do you know when its seated fully? I put a lot of torque on that hub, then backed off the nut and finger tightened like it said in the manual, is there a better way?
Old May 24, 2011 | 05:15 PM
Drawmain's Avatar
Drawmain
Roger, you are the man. The seal wasn't flush, it is now, and all is well, wheel is all good Thanks, Roger
Marc
Old May 24, 2011 | 05:53 PM
...Roger...
Your welcome ,glad I could help.
(once you said the inboard pad was loose I thought the rotor might be spaced out too far)
To Front Brake Issue
