Rollbar in C3 Convertible?
Old May 24, 2011 | 07:27 PM
RickyBerg's Avatar
RickyBerg
Default Rollbar in C3 Convertible?
Hi.
I just started the planning for fitting a rollbar in my C3 convertible.
Its not ment to be an FIA approved thing but it must be solid and properly built to make my life safer if "the **** hits the fan".
It would be nice if it also contained installation points for 2x proper 4-6point harnesses.
Since i sometimes do use my car with the top up it would be nice if the rollbar fitted undernieth the top.
However, theres not much room when the top is down and folded undernieth the lid..
Maybe a 4-point rollbar that is possible to bolt on during track events could be a solution..?
Has anyone got a rollbar on a C3 convertible and how is it constructed/installed?
All ideas input and pictures are more then welcome.
//Ricky.
Old May 24, 2011 | 07:41 PM
RickyBerg's Avatar
RickyBerg
I borrowed this picture from the internet.
Something like this is what i have on my mind.
If its possible to make it work with the soft top..
Old May 24, 2011 | 10:16 PM
71rdster's Avatar
71rdster
If it fits inside of a T-top car, it would fit under the soft top. Your problem is that the soft top rear bow attaches to the deck lid, and the deck lid latches to the body right behind the doors. to fit that roll bar in a c3 vert, most of the deck lid would need to be removed, including attachment points.
Old May 24, 2011 | 10:18 PM
eagle275's Avatar
eagle275
Old May 24, 2011 | 10:39 PM
RickyBerg's Avatar
RickyBerg
Looking at this car the rollbar may appear to be slightly narrower than the one in the coupe.
Old May 24, 2011 | 10:41 PM
RickyBerg's Avatar
RickyBerg
Heres a nother picture of the same car.
It appears that i may be possibly to keep the original latches..
Old May 25, 2011 | 09:05 PM
vettehardt's Avatar
vettehardt
I know it is possible to do. I have seen it on a few cars and they keep the convertible top and lid unmodified. My dad did it with a 65 convertible back in the 80s and I don't believe a C3 should be all that much different.
Here are a couple of pictures I have of a car driven by a guy I kow from Indy. Sorry, I don't have any closeup pictures.
Old May 25, 2011 | 09:14 PM
RickyBerg's Avatar
RickyBerg
Thanks for your reply.
So then it is posably to get the rollbar undernieth the top.
You dont happend to have a couple of closer pictures of how its done undernieth the hatch?
//Ricky.
Old May 25, 2011 | 09:26 PM
eagle275's Avatar
eagle275
instructions and diagrams would sure be nice!
Old May 25, 2011 | 10:08 PM
milo30's Avatar
milo30
Just find you someone familiar with building them and he should have no problem measuring everything out to make it work and be safe.
Old May 25, 2011 | 10:27 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Here's some pics of Snowman's *Bruiser*. He used the same guy that built the bar in my car and they are near identical designs. It's made out of moly which is lighter. The soft top goes up and down, the hard top fits and the side bars go up and clear both tops. That part is about as tricky as anything with the length of a Vette door opening and the small window area. The bar is bolted to stubs that are welded to the frame. The rear decks have to be notched a little. We tried all we could do to keep from cutting it, but to make the bar actually be functional as well as allow the tops to fit required the down bars to go at no more than this angle.
Old May 25, 2011 | 10:49 PM
RickyBerg's Avatar
RickyBerg
Thanks 427Hotrod!!
That rollbar looks just perfekt!
You dont have a picture where one can see the rollbar and the lid a bit from top?
Sorry to ask so much , you see im stuck on my job offshore so im planning as much as i can before getting home to work on the car.
Nice looking car you have.
//Edit:
I now figured out it wasnt your car..
Old May 25, 2011 | 11:06 PM
427Hotrod's Avatar
427Hotrod
The C-3 is actually Doug Plette's. Doug built the car...I built the motor for it. My car is the '67.
Here's the only pics I have that might give you an idea. One is before the paint was shot.
JIM
Old Oct 8, 2012 | 05:16 AM
RickyBerg's Avatar
RickyBerg
Originally Posted by 427Hotrod
Some realy nice looking Minilite replicas you have on that car.
What make ar they and what sizes?
Wat size tyres do you run?
//Ricky.
Old Oct 8, 2012 | 05:33 AM
Katherinejjm's Avatar
Katherinejjm
Old Oct 8, 2012 | 06:16 AM
RickyBerg's Avatar
RickyBerg
Im sorry, i havent been logged in for some time, now my rollbar is completed.
Appart from adding safety, it also definetly added a lot of stiffness to the frame.
Today i woldnt go to a track in a car without one..
This is how the rollbar for my car ended up.
Testing during construction.
This is the construction painted with epoxy primer (later completed with 2 component matte "satin black").
Old Oct 8, 2012 | 06:25 AM
RickyBerg's Avatar
RickyBerg
I have learned that for the rollbar to clear the hatch on the softtop the 2 vertikals needs to be slightly bent to get the top of the bar slightly fwd compared to the coupes that have a greater clearence behind the seatbacks.
I now have thees 2 rollbars in my garage, the straight one is for a coupe and the slightly bent one is for a convertible.
Those vill go on a 1969 427 coupe and a 1968 427 roadster.
To Rollbar in C3 Convertible?
Old Oct 8, 2012 | 09:23 AM
427Hotrod's Avatar
427Hotrod
Congratulations...looks like you got it done!
The coupes are a little different and allow more leeway. Tha top going up and down and the rear deck is a little tricky.
Did you put sidebars in it?
JIM
Old Oct 8, 2012 | 10:20 AM
RickyBerg's Avatar
RickyBerg
Thanks.
I havent put any sidebars in it yet, byt the car is undergoing constant development so i hope i get it done before spring.
Im planning on lose ones that bolts in when on the track.
Old Oct 8, 2012 | 11:03 AM
Kevin68's Avatar
Kevin68
Questions:
1) What diameter and wall thickness (or SCH or SDR) for the tubing? and why?
2) Am I correct that both of these cut the deck lid? I wonder if the rear support went down (on the same plane as the loop) to the harness crossbar, then angled rearward under the deck, would work?
3) Ricky, did you cut the glass in the rear storage area and weld directly to the frame?
4) 427HR, was a permanent side bar that attached higher on the loop and went down more steeply (45* or more) considered? If so, why wouldn't it work?
I will soon be in the process of considering this more seriously and appreciate any input. The lap belts in my 68 are un-nerving.
