pop!!!!
Old Apr 21, 2002 | 09:28 PM
silver79's Avatar
silver79
Default back fire!
hey guys, what do you think is going on for no reason when ever I goose(rev) the engine in park or neutural the engine back fires.not all the time any clues?
help.
[Modified by silver79, 7:38 PM 4/21/2002]
Old Apr 21, 2002 | 09:45 PM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: back fire! (silver79)
I'm just adding my 2 cents worth, and I'm far from being a good mechanic but a friend of mine had a similar problem which turned out to be an exhaust manifold leak. Listen carefully with the hood open, if you can hear a popping noise tighten up the manifolds.
Old Apr 21, 2002 | 10:00 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Timing, retarded timing will cause the back fire you describe :cheers:
Also a too lean fuel mixture :yesnod:
[Modified by yellow 72, 9:02 PM 4/21/2002]
Old Apr 21, 2002 | 10:47 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Make sure that your accellerator pump is working correctly. Like Yellow72 posted, a lean condition can cause a backfire and a sudden increase in air without the additional fuel will put you there.
To pop!!!!
