1982 Master Cylinder
Old May 26, 2011 | 04:16 PM
Steve144's Avatar
Steve144
5th Gear
Default 1982 Master Cylinder
How much break fluid do i need to buy to install a new master cylinder?
Old May 26, 2011 | 04:37 PM
MelWff's Avatar
MelWff
buy 2 bottles
Old May 26, 2011 | 09:26 PM
terry82's Avatar
terry82
you will have to bench bleed it then you have to bleed the brakes at each corner.2 large bottles.
Old May 27, 2011 | 01:21 AM
pepegriffo's Avatar
pepegriffo
Two bottles to start with. Hope no air gets into the lines. Buy a pressure bleeder.
Pepe
Old May 27, 2011 | 11:27 AM
79L48's Avatar
79L48
I bought a gallon. Used half... so 2 bottles.
Old May 27, 2011 | 02:49 PM
hugie82's Avatar
hugie82
I did mine yesterday, it took a little more than a half of quart. Make sure you bleed the lines coming off the M/C I was shocked the master cylinder only cost $28 from Rock Auto
Old May 27, 2011 | 08:36 PM
blue427's Avatar
blue427
you usually don't have to bleed the system when you change the m.c.,just bench bleed the m.c. put it on and tickle the brake pedal.Any air will come to the top.should be good to go.
To 1982 Master Cylinder
