oil filter confusion
Old May 27, 2011 | 11:01 AM
ltblue79's Avatar
ltblue79
Default oil filter confusion
So i picked up oil and a oil filter for my 79 that i just bought at napa. the new filter that they told me would work is only half as long as the one it will replace. This seems kind of odd to me. Is this right or did they give me the wrong filter?
Old May 27, 2011 | 11:16 AM
79L48's Avatar
79L48
There is a long and a short version. As long as the diameter is the same and the pickups/threads are the same it is fine to use the short filter. The shorter one is more convenient if you have headers.
Old May 27, 2011 | 11:17 AM
1yy07's Avatar
1yy07
Default oil filter
get a WIX 51061
Old May 27, 2011 | 11:39 AM
Timsride's Avatar
Timsride
Longer filter gives you more surface area. Small filter wont hurt unless you have dirty oil or go excessive times between oil changes. In which case is I would be more worried about the oil braking down unless your using synthetic.
Old May 27, 2011 | 01:35 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the oil filters for 350 truck applications are about a mile long
Old May 27, 2011 | 01:45 PM
Paul L's Avatar
Paul L
They probably gave you their equivalent of the factory-recommended Delco PF-25. No problem with that although it is somewhat small. I prefer their #1061 which is similar in size to the old Delco PF-35.
Old May 27, 2011 | 02:39 PM
fugawi's Avatar
fugawi
thats the one to use.
Old May 28, 2011 | 12:50 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Yep hes right on the Money (wix) all of the gold napa are made by wix for them.
To oil filter confusion
