chrome bolts needed
Old Apr 22, 2002 | 12:55 AM
flynhi's Avatar
flynhi
Default chrome bolts needed
Looking for some chrome bolts to install my hood hinges. Anyone know where I can find these?
Old Apr 22, 2002 | 02:58 AM
vettedan's Avatar
vettedan
Default Re: chrome bolts needed (flynhi)
flynhi- If you can't find Chrome, get some stainless bolts. They polish up like chrome. Sand them down with 1800 grit and polish them up. It would be nice to own these hings from Ecklers, but at $229.00 :rolleyes:
Dan
[Modified by vettedan, 1:00 AM 4/22/2002]
Old Apr 22, 2002 | 07:23 AM
Brutus's Avatar
Brutus
Don't you have chrome plating places near you? I took all my bonnet (hood) mounting bits and pieces off along with sundry other items and after preparing them as best I could, had them chromed for less than $100.00. As long as you do the preparation yourself, it's a relatively cheap procedure. Certainly nowhere near the price Eckler's want for their pieces. What would you do with a second heap of parts if you bought theirs?
Old Apr 22, 2002 | 08:49 AM
UKPaul's Avatar
UKPaul
flynhi,
Don't bother with chrome. I learnt 20 years ago that it's a waste of time (bound to get flamed now :D ). The threads rust & sieze & if they are removed often then the chrome on the head can crack. Then the heads rust & the chrome eventually peels.
I've just replaced mine with stainless (5/16" UNC) set screws. Get them polished up & they look as good as chrome & stay looking good. Plus the threads won't sieze up as bad. If you've got access to a lathe then machine the tops & then rub down with wet-or-dry (diminishing grades until 600). Then just get them on a polishing mop. If originality isn't a problem then you can machine a slight taper across the heads to give an "aesthetically pleasing appearance" - :cool:
If you get stuck, send me an IM (I'm machining & polishing up so many bolts at the moment that a few more won't be a problem).
:cheers:
Old Apr 22, 2002 | 09:59 AM
Edzred72's Avatar
Edzred72
Default Re: chrome bolts needed (UKPaul)
flynhi,
Paul in 100% correct. Chrome only looks good for a while, and will eventually crack and peel after being installed/removed a couple of times. You also have to chase the threads with a die to remove the chrome plating from the threads, or run the risk of binding or breaking the bolt. For trailer queens... chrome stays nice, but I'm sure your car is not one of those. I've had the expierence of using high quality chrome bolts on motorcycles... fuget-a-bout-it. Polished stainless is the way to go!!! :yesnod: :yesnod: :yesnod: :yesnod:
Old Apr 22, 2002 | 11:38 AM
UKPaul's Avatar
UKPaul
Default Re: chrome bolts needed (Silvr77)
That makes 2 of us! :) What a waste of time & money it was. The chrome was so thick that I had to use metric spanners on imperial bolts. But only for a while - because pretty soon the chrome had flaked off & the good old imperial spanners fit again :lol: Stainless, it's the best way to go (unless you can afford Titanium!).
:cheers:
[Modified by UKPaul, 3:42 PM 4/22/2002]
Old Apr 22, 2002 | 12:12 PM
ylose's Avatar
ylose
or....polished aluminum..... :yesnod:
its light...and purdy ! :eek:
[Modified by ylose, 10:13 AM 4/22/2002]
Old Apr 22, 2002 | 12:15 PM
flynhi's Avatar
flynhi
OK, fellas, I'm gettin the message.
So where do I get Stainless bolts?
Old Apr 22, 2002 | 09:07 PM
vettedan's Avatar
vettedan
flynhi- I buy all my hardware (bolts, nut,etc.) for my business through "High Strength Bolt" in Washington State. They specialize in bolts and hardware. I suppose you have a simular business where you live. If all else fails you can go to Lowe's Hardware any marine supply house.
Dan
Old Apr 22, 2002 | 09:34 PM
Paul L's Avatar
Paul L
Just as an example these are SS intake manifold bolts. They look very nice and stay that way. An entire set for my aluminum intake was about $5.00. They do not have the "correct" head markings but that is fine with me. Available at any bulk fastener store.
Old Apr 23, 2002 | 11:43 AM
Edzred72's Avatar
Edzred72
I was lazy and bought the Arp stainless engine kit from Jegs. $72.00, and comes with bolts for the oil pan, intake manifold, valve covers, headers, fuel pump, waterpump, front cover, thermostat housing, alternator, coil, distibutor brackets and motor mounts. Everything "I" need for my current rebuild, all in one package...delivered to my door. Jegs part # 070-534-9601 sb Chevy. Good Luck!! :cheers: :cheers:
Old Apr 23, 2002 | 10:05 PM
joe73vette's Avatar
joe73vette
Gardner-Wescott Co.
30962 Industrial Road
Livonia MI 48150-2024
1-800-521-9805
(313) 427-0760
The sell chrome grade 5 & polished stainless, hex, socket, button and flat head screws, all kinds of washers & nuts, carriage and bumper bolts and other misc fasteners. They also have engine kits, interior kits, and holley carb bolt kits.
Prices are reasonable, and they have all sizes, metric and inch. The only thing is the address and phone no are 10 years old.
Joe
To chrome bolts needed
