Ignition Poll
Old Apr 22, 2002 | 01:26 AM
ry's Avatar
ry
Default Ignition Poll
which brand should i get?
Old Apr 22, 2002 | 02:10 AM
Ben Taylor's Avatar
Ben Taylor
Default Re: Ignition Poll (ry)
What year and engine do you have, and what are you trying to do?
Old Apr 22, 2002 | 03:29 AM
Robert Holtman's Avatar
Robert Holtman
Default Re: Ignition Poll (Ben Taylor)
I'm using the MSD 6AL. It's the MSD 6 with a adjustable rev limiter. You just change little fuse type things to change the red line.
Old Apr 22, 2002 | 08:23 AM
still-learning's Avatar
still-learning
Not fair... I use a Mallory Distributor and a MSD 6AL... :)
Tim M.
Old Apr 22, 2002 | 08:30 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Ive read some posts about the MSD box giving up the ghost, and some more that say they don't last long. Just a thought. I might even be wrong.
Jake
Old Apr 22, 2002 | 08:43 AM
norvalwilhelm's Avatar
norvalwilhelm
MY MSD 6AL has lasted for at least 10 years. I run it will a modified Mallory Unilite distributor. The advance curves on these distributors wears quickly but I bypassed it with a fixed timming then use a MSD timming computer.
Old Apr 22, 2002 | 09:51 AM
Gordonm's Avatar
Gordonm
Default Re: Ignition Poll (norvalwilhelm)
I am running a Crane HI6 in mine with a stock distributor. I am using a set of heavy duty points to trigger the box. No current is running through the points so they should last a long time. The Crane HI6 box is solid state and has dials for a rev limiter. Running 4 years now no problems.
Old Apr 22, 2002 | 01:13 PM
verskel's Avatar
verskel
Don't know but I still use the 'old' mainstay - POINTS ! :D
Old Apr 22, 2002 | 01:26 PM
WeasleVette454's Avatar
WeasleVette454
Although I had a recent problem with my MSD box I still recommend MSD. The previous owner had used the wrong 12v source to feed the box, and as a result, it failed. Jegs said MSD normally charges $35 plus S/H for bench check and repairs if it is something like burned diodes.
Being that heat is an issue with me (454), I relocated my MSD 6A box behind the right wheel well behind the valane panel.
I run the MSD 6A box, MSD Blaster II Coil, and the MSD Pro Billet tach drive vacuum advance distributor.
Hope this helps :cheers:
Weasle :D
Old Apr 22, 2002 | 01:40 PM
ZORA_RULES's Avatar
ZORA_RULES
Default Re: Ignition Poll (WeasleVette454)
Car Craft just ran an article (latest issue) comparing the MSD6AL, Accel 300+, Mallory Hyfire 4C, Crane Hi6, and Holley Anilater (sorry for spelling and I can't remeber the version)....but they were pretty much even...the Accel box was slightly better but not by more than the deviation allowed for dyno error. I liked the size of the Accel and am very please with its performance so far.
They also tested all of these "entry level" boxes against a Hi priced MSD digital version (like a $500 model..can't remeber name, but for serious track use)...and the entry level models rated well against it.
I have a mixed bag of igintion parts too (Accel 300+box, wires, and plugs, Petronix coil, Mallory dist).
Old Apr 22, 2002 | 03:36 PM
page62's Avatar
page62
Messing with ignition is so far down my "to do" list, it ain't funny. HEI works great for my application. Of course, if I had the old points, coil, and condenser, my attitude my be different... :smash:
Old Apr 22, 2002 | 04:02 PM
Tom73's Avatar
Tom73
You forgot one key piece of info, for what purpose? How is the car to be used? A driver, drag racer, weekend cruiser, road race car, etc etc etc
tom...
Old Apr 22, 2002 | 04:41 PM
73 LS-4's Avatar
73 LS-4
Well in my life I've had 4 different ignition boxes, MSD, Crane and now a Mallory. the only one that went out on me was the MSD 6a, I then switched over to a Crane and it was sold with the old truck. I did a Mallory Unilite conversion on the 73's distributor and I thought it would probably be a good idea to stick with Mallory for the ignition box and rev limiter so I bought the IVc, so far so good and I feel a lot better having the rev limiter with the manual trans. I've seen a lot of MSD 6 series ignitons go out, especially back in the early 90's, don't know if they are any better now. I wouldn't hesitate to buy another Crane though, worked great with my nitrous setup on the old truck. I voted for Mallory since that's what I'm currently running.
:cheers:
Pat Kunz
Old Apr 22, 2002 | 04:49 PM
bigvette1's Avatar
bigvette1
I run a Crane HI-6 box and and an MSD billet distributor with mech. tach drive for 6 years and no trouble.
The Crane box uses RISC microprocessor technology, multiple sparks for 20 degrees of crank rotation and has equal to or greater O/P that MSD, and has an adjustable rev limiter. I have read a lot of posts and talked to people that say the MSD is not as reliable as others. I think the mounting location and proper grounding to the box are key to life. In other words they are probably equal, now look at price.
Old Apr 22, 2002 | 06:35 PM
ry's Avatar
ry
i have a 73 with the L-48. im looking to up it a lil, like around 350HP. hope this helps :cool:
Old Apr 27, 2002 | 02:04 AM
Robert Holtman
I have the MSD billet distributor and coil so I just thought having everything from the same manufacturer couldn't hurt. Hey it fires up in the morning, runs great and won't ping so I'm happy.
Old Apr 27, 2002 | 02:31 AM
Corey_68's Avatar
Corey_68
Default Re: Ignition Poll (Robert Holtman)
I'm running a Vertex Magneto in my '68, it's all self contained. NO comparion to HEI. As long as you have a kill switch to shut the car off your fine. :lol:
Old Apr 28, 2002 | 11:04 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I am using a aftermarket 50000 Volt HEI Iginition and I love it!!!
:cheers:
Olivier
To Ignition Poll
