Clutch pedal stop
Old May 30, 2011 | 01:41 PM
Dave Witman's Avatar
Dave Witman
Default Clutch pedal stop
The Clutch pedal should be held against the rubber stop in full rest position by the spring correct with the rod adjusted correctly. Then the freeplay that your suppose to have is overcoming the spring resistance till you feel the the clutch starting to move. Is this correct. Thanks Dave
Old May 30, 2011 | 03:58 PM
...Roger...'s Avatar
...Roger...
That's it,just a little play before you feel the more solid feel.
