Tach Filter
Old May 30, 2011 | 02:14 PM
76yellow's Avatar
76yellow
Default Tach Filter
I just got my new tach circuit board from Willcox. I forgot I needed the filter too. Will I destroy the new board without a filter ?
Old May 30, 2011 | 02:40 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
much better to be on the safe side and replace them together.
Old May 30, 2011 | 04:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It will not hurt the board. In fact, we actually advise people to use the distributor connection to do a hard wire test before installing it back in the car.
Use power and ground from the engine compartment with no signal wire attached and this will give you zero.... for doing the zero set to install the needle. Then attach a jumper wire from the distributor to test.
The filter smooths the signal and keeps interference out but thats it so you'll be fine until you order one.
Old May 31, 2011 | 07:16 PM
76yellow's Avatar
76yellow
Thanks Willcox.....Will do !
Old Jun 1, 2011 | 09:19 PM
0Willcox Corvette
Former Vendor
To Tach Filter
