Like i mentioned before, once u backfire through a Holley the power valve blows out and fuel dumps into the carb - yes even with check ball/valve protection. Minimum u need to remove the fuel bowls and test/replace the power vlvs. Reading liquid black soot on the driveway tells me more than a little rich.
That behavoir is similar to retarded timing but i see u are using plenty of advance. Here again it would be nice to have a "toolbox carb".
Good luck dg and it was nice to read u found the major vacuum leak,
cardo0
i agree here. black soot on the driveway is a major indication of running rich. as stated, the secondaries are not opening and with these not opening, yet the accelerator pump still spraying in more gas, running rich. if the secondaries open by vacuum, then that tells me when you open the throttle, the vacuum isn't dropping far enough, it may be air flow restriction from your air cleaner. try test driving it without the lid on it, it won't hurt anything unless you drive it through a dust storm
You state something about the jets that makes no sense, "but I followed Lars advise in moving one set to the other position and then bumping up the previous set". If you have a list# 80770 the carburetor came with primary jets of 72 and secondary of 75. The primaries are fine, the secondaries can be 76 or at most 78.
If you changed the primaries to a higher number you are too rich and if you put the 72's on the secondary side you are too lean.
Your air cleaner looks way too short. If you have a 14" diameter filter you should not run anything less than 3" in height or you will starve the engine of air at higher engine speeds.
In referencing Lars and his spot on advice he also touched on the bent accelerator pump arms on the Holley Avenger carbs and new out of the box you had to bend them back in place so they struck the diaphram correctly under the float bowl. If the acc pump arm is not contacting the diaphram fully then you have no helper fuel between the idle circuit and the main circuit. Good luck.
I don't have the info with me at the office, but I moved the secondary jets to the primary and I think I went with 83's on the secondary. this would put it at 75/83.
The big thing with the street avenger carbs was the accelerator pump arm being out of adjustment and lean jetting. I already bent the accelerator arm so that it was position correctly, and I upped the jetting to 75/83.
I will try to run the car without the air cleaner and see if it makes a difference. I will also check the hood clearance with some play-doh.
Thanks for all the suggestions.
This actually a pretty stupid suggestion for your problem. The material type and square inches will determine a differential pressure drop. Which might be a limiting factor as HP goes up. So a 500 hp with a 3 inch element might only make 492 HP with a two inch. Or a 425 hp might only make 420 hp with a 2 inch
It has nothing to do with what you are experiencing
Also if your jetting is way lean you get lean popping back through the carb. Out on the road it will buck and snort. I would look up what the carb came with for jetting and go back to the base line because it will be close and if anything on the rich side from the factory.
I would verify that your timing mark really is close to "Zero" and then set it for 38 degrees with all vacuum blocked off at 3500 rpm.
75/83 is way too rich, for comparison purposes I run a 3310, 780 cfm, which is a much older version of the carburetor you are running. I use 72/78 and Chevy used on the 70 LT-1 70/76. Change the jets and use a taller air filter!
I am pretty sure that I still have the original jets for the primary. I will put the original jets back in.
As for the timing mark, I don't have a piston stop. Is there another way that I can check to make sure that the "0" on my timing tab matches up exactly with #1 at TDC? What about putting having someone hold a long screwdriver in there to see at what point the piston starts to travel back down?
OMG! Don't stick a screwdriver in the spark plug hole, what are you nuts?
Stick a wooden pencil or something in there.
Tonight I put the original jets back in. They are now 72 primary and 75 secondary. They were 75/81. I also looked at the power valve, although I did not remove it from the assembly. It appeared to open and close.
I also verified (with a long pencil) that the #1 cylinder started to go back down after the timing mark on the balancer was at "0" on the timing tab. I advanced it a little to 38* all in.
It seems to idle pretty smooth but it was still putting out black soot on the floor. I did not have time to test drive it. Also, when I pulled the #1 plug, it was pretty fouled with black liquid that smelled like gas. I wonder if it would help to replace all the plugs now. I am running NGK (UR5 I believe).
I would go for new set just to get back to square one You have nice stuff ............. over the net is tough. do you have friend to look at it?
From: Las Vegas - Just stop perpetuating myths please.
U have to select the correct power vlv for your engine.
Originally Posted by dgruenke
.. I also looked at the power valve, although I did not remove it from the assembly. It appeared to open and close...
It seems to idle pretty smooth but it was still putting out black soot on the floor. I did not have time to test drive it...
U need to measure your idle vacuum and select your power vlv so it doesn't dump in fuel until acceleration. There's more to it than that but u should read up before selecting a pwr vlv - maybe Holley's w/s has the info. Regardless u should select the correct pwr vlv for your current combination. I don't see how u can tell a pwr works good enough by looking at it.
BTW pwr vlvs are only 9 bucks each at Jeg's or Summit and at most u will need 2 - though i suspect your carb only uses 1 pwr vlv.
As for a TDC stop i make mine out of an old spark plug. Just bust out the porcelin and tap the hole for a nice 4" or 5" stove bolt - u can use a nut to lock it in too. I read u will soon have plenty of old spark plugs so better than throw them out u can make TDC tools for nearly cheaper than the postage to send u mine.
I picked up new spark plugs today. The parts store also stocks the 65 Holley power valve so I will pick that up tomorrow and change it out just to give it a shot. The carb came with the 65 p/v and my vacuum is around 18-19 hg in park so the 65 should be good.
I know that the accelerator pump is working because when I had the fuel bowl off yesterday, I pushed the pump arm and it shot gas on me. Good thing my wife didn't see it or she would never let me live it down.
IMO and also people that all they do for a living is work on carbs. The chance of blowing out a power valve on a carb built within the last 20 some years is very slim. The passage way going to the power valve diaphragm is very small. The backfire belch pressure wave within the manifold and at the base of carb is very minimal in pressure because of a lack of oxygen.
Power valves rarely blow out. Nitrous motors cause bangs that blow off hoods - they hurt power valves
Even if the power valve is not blown out, do they still go bad? If it is bad, it would make sense why it is running so rich. I'm not sure if it can be the root of the main problem of the severe bog as soon as I put the pedal all the way down (like it's about ready to die).
Like I said before, I have never used a Holley before and I am willing to try anything at this point because I am at my wits end.
I read a few posts about gas washing out the piston rings so they would not seat if it was running to rich. What would those symptoms be? I wonder if that is possible?? I have to wipe the liquid off the plugs everytime I pull them.
I'm trying to think this through. You have a normal idle and your were able to adjust the carb to a very high vacuum level 18 inches.
With the air cleaner off and you just slightly move the throttle do the squirter get wet? A fast blip will make the pump squirt, but they should be adjusted to flow even at a slight move ment. Does your motor rev up not under load in the driveway?
I looked up carburater problems. Read this and I would remove the choke completely. No well tuned motor needs or even has one.
We will discuss two types of bog: the first is bog when the vehicle is accelerated from a stop; the second is bog when the vehicle is accelerated from cruise. Bog from a stop is virtually always (and generally erroneously) diagnosed as a faulty accelerator pump (see the section on “accelerator pumps” for testing). Most modern carburetors are designed to function with roughly 0.020 (20 thousanths) clearance between the center of the throttle plate edge, and the throttle body at a point equidistant from the throttle shaft bearing areas. This clearance allows for maximum velocity of idle air past the idle ports. Exceptions to this are GM carburetors with the idle speed air screw, and end carburetors on tripower. Setting the idle for the highest vacuum idle reading will result in too little clearance of the throttle plate; forcing too much of the idle mixture through the lower idle port and too little through the idle transfer slot. This will cause a phenomena called “puddling” where little droplets of gasoline adhere to the intake manifold runners. When the throttle is opened, there is now sufficient velocity of air to sweep all these droplets into the cylinders, creating a mixture which is too rich to burn, hence the bog. As soon as the overrich mixture is pumped out the tailpipe, and a normal mixture is ingested by the cylinders, the bog disappears. A defective advance mechanism can also cause bog; as can a defective accelerator pump. If bog exists only from an idle, not when accelerating from a constant speed, the idle adjustment is probably the culprit.
Bog from a cruise RPM may be caused by a defective advance mechanism, but on 4 barrel carburetors is often caused by the secondary side opening too soon. Most original equipment 4 barrel carburetors have “on-demand” secondaries (I use this term rather than vacuum, as some early 4 barrels used vacuum to accuate the secondary, while most 4 barrels from about 1960 up used either spring tension or weights to control the secondary). The Carter AFB uses weights, and therefore never goes out of adjustment. Other 4 barrel carburetors such as the Carter AVS, Carter TQ, Rochester 4GC, and Rochester Q-Jet have a tensioned secondary spring. As the spring fatigues, the air valve will open too soon, creating an instantaneous lean condition, and a bog. These units, when rebuilt, should virtually always have the tension spring replaced, and adjusted to factory specifications. A defective accelerator pump will rarely cause bog from cruise.
Sorry...I wasn't able to touch the car this weekend. I had too much stuff going on.
MelWff: I have checked the floats several times...running and turned off. Each time, the gas is right below the sight holes and when I bump the car, it leaks out the hole.
gkull: I believe that if I move the throttle at all, a little bit of gas comes out...when I "blip" it, the squirters shoot the gas in. It revs up strong sitting in the driveway in park.
I don't think the problem is with the secondaries opening too soon because I put a paperclip on the secondary shaft just under the vacuum mechanism, and the paperclip didn't move after I took it for a drive and tried to open it up.
I already changed the jets. I will change the plugs over and take it for another drive and see if it makes a difference.
Your squirters on top of carb may be too big I would pull them to see what size they are and try a set 4 sizes smaller to start with. Be very carefull they have tapered washers under screw and a flat one under squirter. Dont let them fall into carb. I can almost guarantee that this is your problem.
