700R4 in a 78???
Old Apr 22, 2002 | 11:54 AM
bryan78nCO's Avatar
bryan78nCO
Default 700R4 in a 78???
Has anyone ever put a 700R4 4 speed automatic into a 78 SA? How tough is it? What kind of modifications need to be done? I heard that you have to re-weld the crossmember?
I have a 3 speed tranny now and I have 373 gears in the rear end. When I am on the highway doing about 80MPH, I am pulling about 4000 rpm. It is good for around town, but for cruzing, it has to be hard on the ZZ4 motor.
I am just wondering if I should go to a 700R4 or drop the rear end gears down a little bit?
Any help would be appreciated. :smash:
Old Apr 22, 2002 | 12:14 PM
ylose's Avatar
ylose
Default Re: 700R4 in a 78??? (bryan78nCO)
searh the archives on 700R4....its been done many times.
Old Apr 22, 2002 | 12:23 PM
ENCHANTMENT's Avatar
ENCHANTMENT
Bryan,
This is a relatively easily swap and well worth it. I originally had the same transmission as you and the same gearingm in my 1980. I always felt I was winding the engine up too high. With the 700R-4, everything works like it should. Its a great improvement! The engine runs cooler, quiter and you get better gas mileage. The swap has been well documented so check the archives.
Good Luck!
Ken
Old Apr 22, 2002 | 01:16 PM
bryan78nCO's Avatar
bryan78nCO
Default Re: 700R4 in a 78??? (ENCHANTMENT)
Are there certain types of 700R-4's to get for the corvette or are all of the 700R-4's the same? What about putting it behind a ZZ4? I have heard that the stock 700R-4 will break fairly easy if it is bolted up behind any type of performance motor? any truth to this?
Old Apr 22, 2002 | 04:47 PM
mrvette's Avatar
mrvette
What you want is a 700r4 from '88 up in years....and from a truck or impala maybe....you want a standard tail shaft, not a C4 vette thing....
you also want the Trans-Go shift kit...NOT something else...
the later trannies should come with all the late fixes from GM...the earlier ones are full of bugs cost a fortune to update....get a good late core to start with....rebuild kits are only about 250 bux...plus 150 bux for a torque converter....plus 70 for the kickdown cable...plus shorten driveshaft about 80 bux....plus core charge...150 bux.....as you have no exchange....
jGENE
To 700R4 in a 78???
