aftermarket steering box
Old Jun 1, 2011 | 07:25 PM
troythefixer's Avatar
troythefixer
Default aftermarket steering box
Hello, A friend of mine with a big block 72 coupe tells me there is an aftermarket steering box that gets rid of the antiquated and not very good power steering system that is a direct bolt on to the steering column, and that I should be able to find it in the vette mags adds, well I can't find any information. Does anyone have any in formation about something like that..........Tks...............Troy
Old Jun 1, 2011 | 07:36 PM
PeteZO6's Avatar
PeteZO6
What you are looking for is the Borgeson box. It is a new design Delphi 600 unit that is taken apart, the old Jeep mounts are removed, jigged and a plate to fit the C3 is welded onto the box. It is then checked for trueness, aligned if necessary, and the guts installed. You use your pitman arm, but need a new rag joint which they supply. It's a great unit. Here are some links:
http://forums.corvetteforum.com/c1-a...onversion.html
http://forums.corvetteforum.com/c3-t...geson-g-b.html
http://forums.corvetteforum.com/c3-g...n-results.html
http://forums.corvetteforum.com/c1-a...-steering.html
http://forums.corvetteforum.com/c3-t...-steering.html
http://forums.corvetteforum.com/c3-t...g-install.html
In case you haven't figured it out, I love the new steering on my '69 Convertible!
Pete
Old Jun 1, 2011 | 08:56 PM
72LS1Vette's Avatar
72LS1Vette
With the Borgeson steering box you also eliminate the control valve and steering ram. That's at least 2 sources of leaks.
Rick B.
Old Jun 2, 2011 | 06:22 AM
jb78L-82's Avatar
jb78L-82
I know folks have been pleased with the Borgeson steering box but I went another route with my steering using all the OEM components (none of which leak-BTW after 33 years!) by having the OEM box blueprinted/rebuilt and could not be happier! The steering feel is perfect and original steering slop has been completely eliminated-the cost $300. I still have the OEM steering ratio of 16:1 versus the borgeson 14:1 but I don't need quicker steering for the street and was most interested in eliminating the play in the wheel of which I have none now! I am not talking about a standard rebuild or new OEM box built to original specifications but having the internal components replaced with custom modifications like the olite bushing added to the shaft to eliminate ALL play and hand adjusted for feel. Just an option!
Old Jun 2, 2011 | 07:49 AM
MIKE80's Avatar
MIKE80
Same here! Gary does awesome work!
Old Jun 2, 2011 | 02:16 PM
troythefixer
tks, what a great source of information you guys are, I went in looking for one option and came out with two, has anyone driven both the oe box with the upgrades and the borgeson to make a comparison?..............Tks............ .Troy
Old Jun 2, 2011 | 02:21 PM
troythefixer
forgot to ask on the oe rebuild, who is it that does that....................Troy
Old Jun 2, 2011 | 02:51 PM
682XLR8's Avatar
682XLR8
sent you a PM Troy
Old Jun 2, 2011 | 09:03 PM
MIKE80's Avatar
MIKE80
Gary (gtr1999)
He's on DigitalCorvettes.com forums
Old Jun 2, 2011 | 09:24 PM
jb78L-82's Avatar
jb78L-82
Troy,
That is a great question-I have not driven a borgeson equipped C3 to compare to my custom rebuilt steering box but I can tell you that my 78steers, handles, and feels MUCH better than it ever did when it was new. However, I have also taken great pains to eliminate any unnecessry front suspension movement in addition to the blue printed box (all the other changes were done before the rebuilding of the steering box which I just had done last October 2010) including poly upper and lower control arm bushings, a speed direct spreader bar connecting the upper control arms, poly bushings on the Bilstein shocks, poly mounting and endlink bushings on the OEM 1 1/8 inch front sway bar and 255/45/17 ZR ultra high performance summer only tires. Almost every front end component has been replaced-65,000 miles on the L-82 4 speed. With my setup, I doubt that a borgeson box on a stock front end C3 would feel better steering wise BUT I have no comparison yet. Maybe someone else has experience comparing the 2 options.
Old Jun 2, 2011 | 09:25 PM
Roadking's Avatar
Roadking
Gary did my box, rear and ta's.
To aftermarket steering box
