Engine setup help, ideas?
My Engine is the original L-48 with Manual Transmission.
So far i have done a bit of research and looked up some parts from Edelbrock. I was thinking of going all Performer. Meaning that i so far was thinking of buying these Parts:
1. Edelbrock Performer Intake Manifold
2. Edelbrock Performer 600 cfm manual choke Carburetor
3. Edelbrock Performer Cylinder Heads
4. Edelbrock Performer Plus Hydraulic Flat Tappet Cam and Lifter Kit
So far this is what i have thought of. I am also boring the engine out .030" over. Can you guys help me out here buy giving me some advice about this set up?
Will this set up work? Are there more parts that i would need to reach optimum performance with these parts? Would I need a certain type of Piston for this setup? Am I wasting my time with these parts?
Thank You for the help in advance.
what are the casting numbers of your heads?
what type of intake do you have currently?
what type of carb?
any work done to this engine previously?
the cost of boring a block is the same no matter what size you bore it to. and oversized pistons are relatively the same price no matter the size. be sure of what size overbore you want before you do it.
ok, bolt on parts do give more horsepower, but machine work to the block work wonders with the right heads and pistons. my motor is bored .060 over. i have regular old chevy iron 58 cc chamber heads with 1.84"intake and 1.5" exhaust valves (it came out of an 84 caprice but they are commonly called "305 iroc heads"". with my block bored .060" over and the deck height trued and shaved to 9" exact, and forged flat top with two valve reliefs i have 11.75:1 compression. it also has an edlebrock 600 cfm manual choke carb, weiand dual plane aluminum intake (which I hate), a comp cams xe274h (hydraulic flat-tappet) cam, nothing special with the valve train, stock corvette (ram horn style) manifolds and short pipes. all this together gives me a respetive 418 HP and 450 FT/LBs of torque, all of this on a budget (including buying the block) of around $1000.
Whatever the answers, given added performance is your aim I'd urge you to look into other cams and more carb, and to not overlook offerings from other makers before committing to purchase. If you can afford them go for 4032 alloy forged pistons. They'er stronger than any cast or hypers and lower expansion than typical forgings.
Yes, the L48 is a low compression mill so you definitely need more CR, but IMCO 11.75:1 on pump gas is a bit much, especially with limited intake duration. It's not the holy grail, but you ought best to take theoretical DCR (dynamic compression ratio) into account when pairing cams and CR. And, keep in mind the better your heads, the less cam required to flow the same amount.
There are many ways to skin this cat, and a good many SB guys here who know more about them than I'll claim. They'll most likely be able to give you all the feedback on this you'll be able to digest, and more, but the more we know the more applicable that info is likely to be. Hope the above helps get the ball rolling...
what type of carb?
what type of carb?
The intake is the original that came with the car. I'm not sure if it's a certain design though.
As far as I know the engine has not been rebuilt.
What do u suggest I could do to the engine?
This car is most likely gonna be an everyday car... I'm not planning on racing or taking it to drags....
However, since I'm rebuilding the engine I want to build it the best I can. I want to give it as much performance as my budget allows me to yet keeping it civilized.
Reason I chose edelbrock at first because I've been to a few car shows, meets, and auction and I noticed the majority of the cars had edelbrock so I assumed it was a reliable company to base my restroration around.
This is my first build which is why I feel a bit overwhelmed right now choosing the right parts so u guys' help is strongly appreciated.
many people use edlebrock because of price. edlebrock packages there carbs and manifolds and sometimes those with cams and lifter sets. these packages and built and tested to work very well as a package and the simplicity of buying a package proven the work intrigues people. edlebrock gives these packages a horsepower and torque rating so one can chose the perfect package for his/her own needs and budget.
another reason many people buy edlebrock carbs is because they are the simplest carbs to take a apart and clean, and a rebuilt kit (gaskets, needle valves, seats, and filter screens) are around $50 (if i remember correctly). although q-jets are difficult to take apart and rebuild, (and the gaskets kits run more expensive) they provide better economy when running in the primaries and better performance when the secondaries are open.
if you are determined to use your q-jet (and there's nothing wrong with that), I would suggest a dual plane manifold because they have better low-rmp (off-idle) response, more torque and better idle over a single plane manifold.
if a camshaft upgrade is on your lift of parts, i would recommend a comp cam. Not one do they provide a wide veriety of cams to choose from, but they are also well priced with and range of $100-$200 for just a cam, or $300-$500 for a complete package including cam, pushrods, lifters, valve springs and retainer clips.
Sorry I must leave for work, so I must finish this when I come home tonight.
ON that budget I would suggest a bore of .030" assuming the block is fine, a set of Speed Pro Hyper flat tops, rebuild your rods, and go with a set of Vortec heads and Vortec Performer intake manifold, recurve the distributor, rebuild the Q-jet, a set of Summit house brand headers and dual exhaust.
Look for these on any chevy/GM truck produced from 1996 up. Make sure and grab the valve covers too - they're the center bolt style.
care to explain what this is?
acid dip and magnaflux - $54
overbore and honing - $188
deck height shaved - $84
freeze plugs R&I - $42
cam bearing R&I - $20
rotating assembly balanced - $200
so just for machine work in my area is around $550 to $600
if the cost is close to the same in your area, there goes 1/3 to 1/2 of your budget.
make sure you ask the machinist if the block you are using will be worth it to have this done ( mainly that the cylinder walls won't be too thin with an overbore).
whether you decide on vortec heads or older style, or what particular cam you are using, make sure to chose heads, cam and have your block work done before buying aftermarket intake and other non-power adding parts.
