78 fuel tank question??
Old Jun 2, 2011 | 01:24 PM
GT's 78's Avatar
GT's 78
Default 78 fuel tank question??
I,m to the fuel tank on my resto and got all gas out and noticed there is a plastic tank on the inside of the metal tank. There is gas trapped between the two tanks. There dosent seem to be any holes in the plastic tank. How did this gas get in there? Is there definitely a hole in the plastic tank? There is a cavity in the plastic tank under the vent line. Could gas over time have sloshed to this cavity? I'm not wanting to shell out 250 for a tank if I dont have to for mine seems ok other than this mystery. Any advice would be helpful.
Old Jun 2, 2011 | 07:00 PM
GT's 78's Avatar
GT's 78
ttt
Old Jun 2, 2011 | 09:21 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you have fuel between the tank and the bladder then you have a hole in the bladder. The bladder was one giant lining inside the take and part of a safety re-vamp by GM.
Can you remove the bladder.. I've never tried it but from what I understand it can be done. You'll need to save the very top of it that seals the neck to the tank but it can be done.
If you leave the fuel behind the bladder over time it will grow stale and enter the fuel system. Another issue that fuel behind a bladder can cause is an incorrect fuel reading. Not because the fuel is behind the bladder but because as it grows behind there the bladder will usually push inward and hit the sending unit arm float.
Willcox
Old Jun 3, 2011 | 09:37 AM
KENS80V's Avatar
KENS80V
Willcox
His tank is from a 78 which doesn't have a bladder (78 to 82 are the same). It has a hard plastic liner (high density polyethylene). They cannot be removed. The liner dry rots over time and will develop cracks. There is no replacement tank available with this liner. All the current replacement tanks are just steel with no liners or bladders.
Don't feel bad. Your tank lasted 33 yrs. Get a new one for piece of mind.
Old Jun 3, 2011 | 10:25 AM
GT's 78's Avatar
GT's 78
Once the tank completely dried I did see some cracks in the plastic tank. Call me crazy but I'm going to attempt to cut this tank out with a razor knife and snips, clean inside of metal tank, seal with por15 tank sealer. If anyone knows this wont work please let me know
Old Jun 5, 2011 | 06:14 PM
0Willcox Corvette
Former Vendor
Ken... They must soften up over time because we just replaced one in our shop about six months ago and the liner was pushed out so far the arm from the sending unit was hitting it. This car was an 82...
But I can't imagine trying to remove one myself.
To 78 fuel tank question??
