Relay Question
Old Jun 3, 2011 | 08:10 PM
kilowatt's Avatar
kilowatt
Default Relay Question
What does the relay do that is located in the compartment where the jack stores?
Old Jun 3, 2011 | 08:52 PM
shrekviper's Avatar
shrekviper
In '69 it was for the alarm...
Old Jun 4, 2011 | 06:53 AM
kilowatt's Avatar
kilowatt
Default relay
my car is a 70 so i assume it is the same. anyone else?
Old Jun 4, 2011 | 08:11 AM
...Roger...'s Avatar
...Roger...
70 is the same,do you only have 1 relay in the compartment ?
Old Jun 4, 2011 | 09:01 AM
kilowatt's Avatar
kilowatt
yes, i only have one. do you have more than one?
Old Jun 4, 2011 | 09:39 AM
...Roger...
If you only have 1 and the car is stock its the alarm relay and you should have a flasher also. Wiring should be pink,black,white and yellow.
Old Jun 4, 2011 | 10:22 AM
kilowatt's Avatar
kilowatt
i saw only one when i looked. the relay cover was eat up with rust so i will need a new one. there was a two prong clip next to the relay but i assumed it was the clip for the jack.
To Relay Question
