Starter clearance issue.
Old Jun 4, 2011 | 06:26 PM
lilmonster's Avatar
lilmonster
Default Starter clearance issue.
I have a '75 that had the starter go out,
when i removed it I noticed that the new corvette central exhaust i got is Really close to the starter, almost touching.
It's so close that I'm kinda thinking that it may have helped kill the starter.
I looked at the replacements and their the same size as the original.
So now I'm wondering if i should get a mini starter.
is it normal for the exhaust to be so close?
would a new starter be ok?
or should I continue looking for a mini starter?
Thanks for your help.
Old Jun 4, 2011 | 07:43 PM
tnovot's Avatar
tnovot
How close is close? Can you make a heat shield out of galvanized sheet metal or a piece of AL with small tangs which could be used to clamp it to the exhaust pipe?
Mini starters have been used in many applications in the Corvette and hot rod scene with good results.
Terry
Old Jun 4, 2011 | 07:53 PM
lilmonster's Avatar
lilmonster
Terry
it's so close that adding some sheet metal would make them touch, you could slide a sheet of paper between them.
and thanks for your reply.
Old Jun 4, 2011 | 09:43 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Do you have the heat riser flapper thingy in place between the manifold and pipe?
If not, isn't there like a 2" spacer that goes in it's place?
Old Jun 4, 2011 | 09:50 PM
lilmonster's Avatar
lilmonster
Yes, there was, but the new exhaust pipe set came with a spacer to replace it.
just to be safe, i'm going to go measure them to see if the new spacer is the same height as the flapper.
Old Jun 4, 2011 | 10:00 PM
Timsride's Avatar
Timsride
I would go with a mini torque starter and did on my vette. If someone wanted the original style starter back in it is a fairly easy job. The mini's work so much better as well.
Old Jun 5, 2011 | 07:58 PM
lilmonster's Avatar
lilmonster
After doing some price checking on the mini starters, I went with a re-manf from the local store.
But now the new starter has 3 connectors on the solenoid, the old one only had 2,
So what do I do with the 3rd extra post on the new starter?
Old Jun 5, 2011 | 09:23 PM
Oldguard 7's Avatar
Oldguard 7
R terminal is for points type ignition. My current starter close to the exhaust header collector. I can only loosen the bolts and they touch the header collector. I am going to remove it in replace it with a mini starter I bought off of fleabay. Once replace =d, I should have enough room to remove the starter should I need to and wont have to do with the hot start issue. (due to the weak solenoids on most aftermarket regular starters)
Old Jun 12, 2011 | 05:13 AM
lilmonster's Avatar
lilmonster
Sorry it takes me so long to reply, I've had a busy week and just got it fixed today.
And that spacer supplied with the exhaust pipe set was the problem, it was about 3/4" shorter then the flap assembly.
So i ended up taking thew flap assembly apart, tapped the hole and put a bolt in it.
i reinstalled it today and now the pipe is a nice distance away from the starter.
To Starter clearance issue.
