wiring help
Old Jun 5, 2011 | 06:10 PM
63vert's Avatar
63vert
Default wiring help
In the process of replacing the dash, engine and forward lamp harnesses in a 74 coupe, the conector for the anti theft portion of the harness has 2 wires, 1 black and 1 white. The lock cylinder located in the driver's side fender has 2 lugs with screws coming out the back. There must be something that bridges these two together but I can't seem to find anything in my assembly manual or online. There was so much of the car missing when I started all this, I don't have much to go on to undo all the creative engineering done to this car by previous owners. I'm assuming there is a jumper harness or adapter/ extesion I don't have. If you know what this needs, great. What would be better is if someone knows where I can get one.
Charlie
Old Jun 5, 2011 | 07:07 PM
...Roger...'s Avatar
...Roger...
What you have in your hand goes to the anti-tamper switch that protects the alarm switch.
Alarm switch should have a pink and orange wire.
You need the anti-tamper switch which is the same switch as the headlight warning switches.
You also need the bracket that holds the tamper switch.
Old Jun 5, 2011 | 07:21 PM
63vert's Avatar
63vert
That sound like what I'm looking for. Any idea where I can find these? I've been serching the parts guys but no luck.
Charlie
Old Jun 5, 2011 | 07:24 PM
...Roger...
Here's the switch
http://willcoxcorvette.com/product_i...oducts_id=6172
Old Jun 5, 2011 | 07:28 PM
...Roger...
This shows how it all goes together.
http://willcoxcorvette.com/popup_image.php?pID=25898
Old Jun 5, 2011 | 07:31 PM
63vert's Avatar
63vert
I see where the conector on the harness matched the end with the prongs, how does the other end make it to the lock cylinder? Sorry to sound so dense on this, most all this is missing on the car.
Charlie
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Thanks Roger-
The wire in your hand plugs in to the end of number 1 in the picture.
Old Jun 5, 2011 | 07:34 PM
0Willcox Corvette
Former Vendor
There should be a orange and pink wire that has round loops on the end of it.. these two wires go to the switch and there should be plenty of room to pull them over there.
Old Jun 5, 2011 | 07:42 PM
63vert's Avatar
63vert
You guys are great, thanks for all the tech info so fast. I'll have to do some looking to see if I can track down the pink and orange wires. Like I said, most of the wiring in car is either hacked, bypassed or just plain gone.
Thank you again for all the help, this system is starting make sence now and hopefully I can get this straight.
Charlie
Old Jun 5, 2011 | 07:53 PM
63vert's Avatar
63vert
Light is starting to come on finally. The orange and pink wires are part of the forward lamp harness. (starting to feel like I've got it)
Thanks everyone. This forum has always been a great place with good people.
Have a good day
Charlie
Old Jun 5, 2011 | 09:00 PM
0Willcox Corvette
Former Vendor
Glad to hear it..
To wiring help
