Windshield Washer Pump Question
Old Jun 6, 2011 | 08:28 AM
DonW's Avatar
DonW
Default Windshield Washer Pump Question
I'm working on my 72 and have the pump and motor assembly out for cleaning and checking. I took the cover off the pump and a small spring and metal piece came loose. In looking at the gear assembly on the pump there is a larger spring attached to the metal arm near the gear. I cannot figure out how to reinstall this other smaller spring and metal piece. If anyone has a picture of their pump assembly that shows the gear area with the springs installed I'd be grateful. I've searched the web and the forum and can't find a photo or description for the install. As always thanks for the help.
Old Jun 6, 2011 | 08:57 AM
...Roger...'s Avatar
...Roger...
Check the video in this link and see if it helps,if not Willcox probably has a closer pic he can share with you.
http://forums.corvetteforum.com/c3-t...-stuck-on.html
