brake caliper ?
Old Jun 8, 2011 | 09:49 AM
learje's Avatar
learje
Default brake caliper ?
my fronts are leaking, id like to rebuild them with o-ring pistons. do all original calipers have the stainless steel liners that are apparently required for this conversion?
my cars a 73
thx!!
Old Jun 8, 2011 | 10:37 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
no, but its hard to find a set of original calipers. most have been replaced somewhere along the way and have already been sleeved
Old Jun 8, 2011 | 10:47 AM
learje's Avatar
learje
thx! so the only way to know for sure is to pull a piston?
Old Jun 8, 2011 | 10:48 AM
Mike Ward's Avatar
Mike Ward
No original caliper has SS liners, that's purely aftermarket. SS liners are not mandatory for o-ringed pistons.
Old Jun 8, 2011 | 12:11 PM
learje's Avatar
learje
okie, so the same size pistons would fit either sleeved or non sleeved calipers?
Old Jun 8, 2011 | 12:59 PM
bobs77vet's Avatar
bobs77vet
yes....when they sleeve the calipers they over bore them....you would only want to use the SS calipers the chances of finding an original caliper that is not pitted to death is next to impossible
Old Jun 8, 2011 | 02:45 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by learje
...do all original calipers have the stainless steel liners...
No original calipers were stainless steel sleeved. The sleeved calipers are aftermarket.
Old Jun 8, 2011 | 04:49 PM
learje's Avatar
learje
thx guys, PO says they r only a few yrs ole, so hopefully they r sleeved. ive ordered 1 O ring conversion kit, ill know for sure, when i pull the worst of the calipers apart, what i have
thx again!
Old Jun 9, 2011 | 11:06 AM
bobs77vet's Avatar
bobs77vet
its easy to loosen the caliber halves when they are mounted.....this way the car acts like a big vise(sometimes these are a pain to loosen)...all you need to do is loosen the bolts that hold the two halves together.
To brake caliper ?
