Help! Custom power steering very hot!
Old Jun 8, 2011 | 11:04 PM
70_Shark's Avatar
70_Shark
Default Help! Custom power steering very hot!
I installed a March serpentine belt system on my ZZ502 and thus had to use a different power steering pump from a newer model GM. I bought a aluminum fluid canister and plumbed it together with braided hose and AN fittings. I always thought It felt warm but tonight I severely burnt my forearms on the canister when I was tightening my header bolts while it was running. I opened the canister and it was steaming hot. I have been messing with the fittings because of leaks and at one time the hoses were reversed at the control valve for a couple seconds. The control valve is brand new and so is the cylinder. Do you think that I burnt out the pump? Why would it be running extremely hot? Thanks.
