Vortec style Edelbrock intake question
Old Jun 9, 2011 | 11:00 AM
russde's Avatar
russde
Default Vortec style Edelbrock intake question
Doing some future planning and have a question (actually a bunch of questions, but will start with this one).
Stock type fresh short block.
I am considering Scoggins Dickey modified Vortec heads, I'd like to keep my quadrajet, so how much power am I potentially leaving on the table by needing a spread bore intake (Edelbrock Performer) vs going with a square bore and using the Air Gap?
Street driven, occasional auto-x, some daily driving in this cars future.
Ok, two questions...what cam recommendations for the above?
Thanks,
Russ (dreaming of driving my '70 instead of dusting it in the garage)
Old Jun 9, 2011 | 02:58 PM
BKbroiler's Avatar
BKbroiler
I have Vortec heads and a Qjet. I was using an Edel. Performer (not RPM). I switched to an Edel. RPM air gap which required an adapter to use with the Qjet as you apparently know. I drag race my car occasionally and I believe I actually slowed down a tenth by changing manifolds. Some theorize its the adapter that is the problem. I'm not sure, but overall I don't think you're giving up much using the Performer. As for camshafts, I'm using a Comp XE262 flat tappet hydraulic. Excellent low and mid range power. Probably good for autocrossing.
Old Jun 9, 2011 | 03:02 PM
doctorgene's Avatar
doctorgene
I have installed two engines W/ vortec heads, & installed two new intakes, with the Q-jet carb. Maybe you could pose this Question directly to Edelbrock! I think they have a help line. Have a great day. Gene
To Vortec style Edelbrock intake question
