BIG power guys: staying in control
Thanks gkull and Jim, you're the type of guys I wanted to hear from. I have plenty of good, straight roads I can learn on. I haven't bought tires yet - other than Khumos and Nittos, what are some good street tires that'll help to control a lot of power?
FWIW I've done a fair amount of both drag and road racing, so I do have an appreciation for both. My own priorities having shifted even moreso towards the latter type of performance, not too long ago I aborted doing a 496 build in favor of another hi-po 427. The more modeling was done the more apparent it became that the more gradually building torque and higher RPM power profiles of the 427 in question just far better suit my particular purposes.
Bottom line, whatever your purposes, IMHO you'll be happier in the long run if you strive to match your engine up with how near to achieving them your tires (the best affordable) will allow you to get. My $.02
TSW
After using this experience for years, I've noticed that:
1. I am not as fast as the ***** to the wall guys.
2. I've wrecked fewer cars, blown fewer motors, and go through less tires and women.
Even with my approach at tackling vehicular and personal limits (never exceed your skill), I've gotten into some hairy situations as I mentioned before. The biggest problem with approaching a high power car is to retrain your INSTINCTS. No matter how careful and cautious you are puttering down the road at your cruise in, how are you going to react when someone sweeps into your lane? What if you get irritated at a slow mother--- and do a quick downshift and try to floor it past them: and forget your surface check and hit gravel?
That's what you need to be careful about, and I've found after having driven a 500 hp car for 5 years the following:
1) 500 hp is a pretty reasonable limit, as mentioned by gordonm. There's very few street tires that can hold it straight, and coming out of corners in first gear you have to be VERY judicial.
2) It's not as fun as you'd think. I think for a twisty road, a Porsche Boxster S would be more fun than the Z06. Doesn't necessarily mean it's faster, it's less stressful to drive hard and probably more rewarding.
3) 500hp is VERY hard to plant in a RWD car in low gears. I autocross. I could loop the car easily if I sneezed with my foot on the throttle on corner exit.
As for tires, that kind of power will put you at the level where I'd be wanting to run multiple wheel/tire combos so I can have a nice summer compound (Michelin Pilot Sport Cups, Kumho Ecsta XS, Nitto NT05s (listed in decreasing dry traction capability)) and then a nice all season tire, like Goodyear F1 GSD3s, Nitto Invo and others. The dry tires will perform poorly on a wet road, vice versa for wet on dry.
One thing you'll probably find by iterating your motor as such is that not only is there more power, but the personality of the motor will change. It could very well be that the first motor you build is a torque monster that just lights the tires off all the time, and the second seems pretty reasonable until you hit the cam's sweet spot and then watch out! (spin)
My Z06 has more torque down low than the car it replaced (an 02 Corvette), but doesn't "wake up" until 4500 RPM. I've had it get wonky going straight and hitting said "sweet spot".
Hope that helps.
I'm sure I can detune a 565 to 650hp, which will be closer to about 550 at my altitude, then pick up the program once I get used to that power...if I ever decide to change.
My experiences have always been that I always want more, whatever it is.
That's where the L88Plus came from
I blame Jim for that one, he's always raving about how much fun a higher revving mill is, making power up in the range where you can use it rather than having a tow truck engine with massive bottom end torque.
I wonder if a 6223 forging could handle 7000 with today's lighter pistons and rods? They're plentiful and will balance easily. My calculations put a modern piston/rod combo at about 5 ounces less per cylinder than an L88 was...
For what you're looking to build, I'd just deal directly with JE and have them make you a set of 4032 forgings for your specific application. That way, not only will you save some $$ (vs buying thru someone else), you can also get the domes (blended), ring and compression heights right where you decide. I'm going with the expansion groove, but skipping the gas ports.
Something you'll need to start watching when revving a BB is valvetrain weight and component stiffness. Don't skimp on these bits! Smaller valve stems and titanium retainers are a good call, at a minimum, along with quality rockers and pushrods. And, don't under spring! Suggest a 4/7 swap, but in any event I'd go with a steel cam core with iron gear. Remember, the valvetrain won't care how big are the cylinder bores, rather how high you rev.
Thought I'd share some of how I'm going about my own L88'ish build, in case it's worth $.02
It's all about discipline.
Also, be careful de-tuning as you don't want to end up with all the bad street manners and none of the power. It's not just cheaper than redoing it but more likely to lead to a better result when approaching a build "holistically."
I can flat hammer mine from a 20 mph roll and it dead hooks if the tires are warm and the street surface is good.... This is with 670lbs of tq at the crank... BUT my car is an auto and only has 3.36 gears....both of those soften the hit to the tires....AND my suspension is setup more for street cruising and drag racing....not corner carving..
Only problem with running the MT ET Streets is they wear out fast....and they are not great in the rain.
Alan's 496 is running a 230'ish HR and cruises fine and makes stupid power into the 6000 rpm range. Keeping milder gears like he has and letting it *work* would be a lot of fun in a street car. Just think of his combo with another 70+ cubes, better heads and just a hair more cam. Talk about fun from a 30 mph roll!
JIM
Traction Control is the answer. We run a traction control system on our X275 Drag Radial car. It's a 518" BBC on one huge kit (550-600 HP)Try to hookthat up on 275's!
Traction control is a must with that combo. there is some excellent stuff out there that really works. 4's in the 1/8th @ 149 MPH 1.19 60ft.
PM me and I'll give you more info if interested.
JIM
Yeah thats what I'm wanting....
I see me and you building me a 555, maybe those 3Xtras you tested and a decent sized solid roller.....and I would LOVE to do the Holley XFI injection...... Basically your motor and FI system....MAYBE a tad less cam just so I easily idle it every where with the AC on....... 850hp should be just enough....Ofcourse I will keep my 3.36s(if Mike's Super 10 bolt stays together...LOL) and have a killer 200R4 in it....
High 9s with AC that I could drive every day......Sounds like a plan...
Did I mention drag radials...? LOL Gotta keep that big power under control.....
JIM
