72 Frame question
Old Apr 22, 2002 | 11:32 PM
C3PO's Avatar
C3PO
8th Gear
Default 72 Frame question
Can I use 78 frame dimensions to straighten the frame of a 72?
Old Apr 22, 2002 | 11:36 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: 72 Frame question (C3PO)
Is that a custom made tilt front with headlights and hood integrated into the body?? Looks just like my setup!!! :cool: :cool:
:cheers:
Olivier
Old Apr 22, 2002 | 11:53 PM
C3PO's Avatar
C3PO
8th Gear
Default Re: 72 Frame question (GrandSportC3)
Yes. It was an old style Eckler's tilt front end. I spent 8 years profecting it, and wrecked it in one day at Carlisle( last year)... I'm having the frame straighten out right now, and the shop I have it at is using the dimensions from a 78. I'm not sure if there the same. I was hoping someone knew.
Old Apr 23, 2002 | 01:28 AM
mrvette's Avatar
mrvette
they essentially are the same, except for the rear most 15 inches or so, and the front section for crash bumper....but from frame horns backward it's the same dimensions....
Old Apr 23, 2002 | 09:59 AM
Tom73's Avatar
Tom73
I would assume that a frame shop would have the "book" that gives all the frame specs. Forget the name of that sucker but it is one big book and has the specs for all american frames. If they are not a frame shop would assume they would have contacts at a frame shop that would share the info with them. If not, then I would be conserned about their ability to work on frames.
tom...
To 72 Frame question
