But you have to cut it and extend it a few inches to get it to reach. Holley includes the parts and instructions to do it. Just put a brand new one on about 3 months ago.
Would either of you happen to have a picture of how you set up your fuel inlet?
I'm not throwing in the towel on my Q-jet by any means, but I am considering my options should it not work well (engine just about ready to run). I'd love to spend the time to get the Q-jet right in any case, but that's just time I am not going to have. If there is a viable option "right out of the box", I'm going to consider it. Folks seem to have pretty good luck with these carbs.
I am traveling for work through Friday so I cannot send you a picture-Send me a PM. The stock fuel line will NOT hook directly up to the 4175-You have to either cut the OEM line and install a short piece of rubber hose between the OEM line going into the 4175 and the rest of the line to the fuel pump (3-4 inches) or run a new line. I have had my 4175 on my L-82 since 1985 and it was much better than the Q-jet which is OK as long as it runs right but once the Q-jet goes south, good luck trying to correct the issue. In my opinion the Q-jet is way overly complicated for what it needs to do. It almost seems that GM was using a complicated carb in a crude attempt to precisely meter the fuel rather than use the more sophisticated/expensive mechanical fuel injection available at the time. I just rebuilt my 4175 in Dec 2010 and it was really easy after 25 years on the car. Try that with a Q-jet-rebuilding it and having run well for that amount of time!
Thanks, you answered my question. I'll PM you for the pic.
I have tried to build hard line once, and never really had the time to progress beyond being terrible at it. Seems to me that with the right combination of fittings and filters, one might be able to make it work without the rubber hose (which I'd rather avoid if at all possible).
