All dash lights are out ??
Old Apr 23, 2002 | 01:04 PM
John Cassidy's Avatar
John Cassidy
Default All dash lights are out ??
I was driving along, hit a bump and out went the dash lights. Haven't checked thefuse yet but it's probably ok. Can someone tell me where the ground connection is for the dash (75 conv). Any other suggestions would also be appreciated.
Thanks,
John.
Old Apr 23, 2002 | 01:31 PM
verskel's Avatar
verskel
Default Re: All dash lights are out ?? (John Cassidy)
All lights ??? :confused:
Sounds like a fuse - there's a ground for each cluster (I think - 1 for speedo and 1 for tach)....plus there's mulitple bulbs which are probably fine unless you had a short ! :eek:
Old Apr 23, 2002 | 04:19 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
I have a loose connection in my light switch - jiggle that first before you do anything else! I still have to jiggle it a bit when turning on the headlights. Should probably replace it someday... :yesnod:
To All dash lights are out ??
