rear dif help please
Old Jun 15, 2011 | 09:46 PM
criggy's Avatar
criggy
Default rear dif help please
The clip that holds in the drivers side yolk to half shaft is comming out is this a common problem . Thanks for any help is this clip the only thing that holds the wheels to the dif.
68 ,327. would a sway bar help.
thanks,Anthony
Old Jun 15, 2011 | 09:58 PM
johnt365's Avatar
johnt365
If you are talking about the snap ring inside the differential then yes that is what holds the yoke in. I just removed my dif and one of the clips was missing. The yoke slid right out.
While in the car it was not an issue though.
Old Jun 15, 2011 | 10:05 PM
Gordonm's Avatar
Gordonm
Do you have the diff out of the car and apart? The clip is inside the diff and yes that holds the yoke in the carrier.
Old Jun 15, 2011 | 11:27 PM
criggy's Avatar
criggy
the dif is comming out again tomorow the mecanic wants to cut the gruve a little deeper and use a different clip. I think there must be something wrong causing pressure on the clip. This car is killing me
Old Jun 16, 2011 | 01:40 AM
naasaa's Avatar
naasaa
I have the same problem.
Yoke at passenger side came out.
I took the diff out for dismantling and inspection.
The C-clip was laying in the diff unharmed. grooves looks fine as well.
The shaft for the spider gear have signs of contact with both yokes.
At the moment I'm trying to figure out how the remove the posi springs in a good manner, and not having them flying out.
Anyone here with a great tip of how to remove those springs?
Lars
Old Jun 16, 2011 | 05:48 AM
Gordonm's Avatar
Gordonm
If the yokes are worn down there is nothing to do but replace them. I have some pictures of worn yokes and recutting the groove will not help the situation. Sometimes it is cheaper in the long run to do it right.
Old Jun 16, 2011 | 07:29 AM
thegazman's Avatar
thegazman
Default thegazman
Having a clip missing from a side yoke can be an issue as the rear of your vette will not be stable while driving on a curvy road. I know from experience. While you have it apart, why not install new yokes and eliminate the problem.
Old Jun 16, 2011 | 08:47 AM
rugerm44's Avatar
rugerm44
just changed both of them due to wear.
Old Jun 17, 2011 | 08:06 PM
criggy's Avatar
criggy
the yokes don't look worn to me is there anything else that would make the clip come off.
Old Jun 17, 2011 | 08:15 PM
68blueshark's Avatar
68blueshark
does the car make ant weird noises when this happens?
I have a 68 327/4 speen and I am getting a knocking at slow 10 mph speeds. Both half shafts and drive shafts are new.
Ed
Old Jun 17, 2011 | 08:42 PM
johnt365's Avatar
johnt365
I am curious how many times this has happened to you and is it the same side each time?
Also, does the same person reinstall the clip and is that person you or someone else?
I ask because of the possibility the clip not snapped all the way in. I would suspect improper installation unless you personally verified.
Old Jun 17, 2011 | 08:44 PM
criggy's Avatar
criggy
I had the gear changed from 308 to 355 mech said bearings were bad in trailing arms and bushing bad on drivers side. I said change what ever, diff shop said one yoke bad thats why clip came out I said change it.Mech (good friend) test drove car making noise after 10 min back on lift clip out again noise in rear spacer chued up, rear out again. but to answer your question I had a noise once in a wile before I touched anything and I think it was from the wheel bearing in the trailing arm
Old Jun 18, 2011 | 04:44 PM
Vtechcorvette's Avatar
Vtechcorvette
We rebuild a few of these a week.
Maybe one out of 30 units that are sent in by customers because the snap rimg came off. Examination of these stub axles shows generally the grove is not deep enough or square and or the snap ring feels not quiet 'tight' as a new snap ring so the snap ring does not seat quite right.
Before putting any stub axle back in always check the snap ring for fit. We have re machined the grove on the lathe and never had one come back.
We generally recommend replace replacement stub axles with hardened tips. (These come with new snap rings)
To rear dif help please
