Instead of header wrap...
Old Jun 21, 2011 | 01:52 PM
Golden's Avatar
Golden
Originally Posted by mikejpss
Wrapping hedders does NOT increase the hedder temperature. It will only increase the residence time the heat stays in the hedder metal. Manufacturers are voiding the warranty on those that are wrapped b/c they can, and they will make more money. If you would like discuss metal and heat transfer, I'm game. Disclaimer. I AM a rocket scientist.
My hedders are wrapped, just ordered the plug boot wraps too.
Explain this to me:-
How is the external temperature of a header no different in the fast moving engine bay air of a car at 60mph compared with no air contact at all, encased in header wrap that reduces heat transfer by 70%
Old Jun 21, 2011 | 04:22 PM
eagle275's Avatar
eagle275
Old Jun 21, 2011 | 09:05 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Pi x r2 ./. 70 x 60 mph - 85 (ambient) ./. insulation value x heat coefficient (assume 3.79 v for mean)...
when you get that equation, let me know.
Old Jun 21, 2011 | 09:43 PM
Wrecked82's Avatar
Wrecked82
So I see alot of posts, here and in other posts, about how bad the header wrap is, but wonder if most of the nay sayers have experience in actuality or in repeating what they have heard and read elsewhere, vs. those that have actual experience.
Just saying. Don't get your panties in a wad.
Old Jun 22, 2011 | 02:35 AM
Golden's Avatar
Golden
mikejpss + OP x bogus post + pompous drivel - goldens question = BS
See if you can work that out
Old Jun 22, 2011 | 06:22 PM
KevinK's Avatar
KevinK
What he is basically saying with that formula, in plain english is, enerhy has to come from somewhere. Heat is energy. The wrap istelf is not adding energy to the equation, so the headers, even wrapped, can only ever get as hot as they ever did without the wrap. That's physics.
The problem is, some of these old cars leak. Ever had a few drops of oil get on your pipes after changing out the filter? Every had a splash of anything get, pretty much, anywhere, while working under the hood? I know I have. Most of those compounds are highly corrosive to metal, and when heated, it accelerates that action. Or it just catches fire, and trust me, that wrap burns HOT. That doesn't happen often, though.
I have personally seen a set of hooker headers that were wrapped before instalation, brand new, then installed on a car that gets driven less than 3,000 miles a year, and the headers were junk 5 years later. And those were a 700 dollar set of big block headers. Is that gonna be everyone's story? Nope. But it's mine.
Old Jun 22, 2011 | 06:38 PM
johnmb's Avatar
johnmb
Originally Posted by KevinK
Heat not being able to escape, which is the primary issue with wraps, will still be an issue... Though it seems not QUITE as much.
I think that is precisely the purpose of both items.
Old Jun 22, 2011 | 06:41 PM
johnmb's Avatar
johnmb
Default Nope
The same amount of heat energy is added to the header.
When you wrap it, it's not going to be able to get rid of the heat as efficiently or as quickly it does UNwrapped. The temperature of the header will be increased with the wrap. It's just as the surface of your skin is warmer in the winter with a coat on as opposed to wearing short sleeves.
Old Jun 22, 2011 | 07:05 PM
KevinK's Avatar
KevinK
That's a physical impossibility without some form of chemical reaction, or EXTREME pressure.
The exhaust gasses leaving the motor is what gets the headers hot. That exhaust gas, right out of the motor, not a few feat down the pipes, but right out of the motor, is going to be the same temp against those headers, wrapped or not. Since that gas is the source of heat energy transferred to the metal of the header, the header can NOT, without extreme pressure or chemical reaction, get hotter than said gas.
It CAN and WILL stay at that max temp for a much longer period of time, though, and heat accelerates almost all chemical reactions.
Ever watch myth busters? They tested a myth where a dude put hot sauce on his prison bars, and then heated it with electricity from a radio. The result? Bars with no heat source, just hot sauce, had NOT corrosion. Bars with sauce AND heat source had SIGNIFICANT corrosion. Substitute hot sauce for brake fluid, gas, antifreeze, power steering fluid, any number of the things can and most likely WILL get dripped onto those headers at some point. Or salt, either from the road or air. Even car soap.
All of these things will be absorbed by wraps.
It's a motor of pros vs cons, and how you plan to drive the car, where you live, etc.
I live in CT.
Old Jun 22, 2011 | 07:38 PM
Golden's Avatar
Golden
mikejpss has a lot to answer for, he's full of it.
He made a contradictory point to something that nobody said
I've just looked back through this thread and can't find where anyone has said there will be an increase in the maximum attainable temperature by headers being wrapped
Having said that, both mikejpfullofit and kevin are both making an irrelevant point. Anyone with a basic knowledge of physics knows that the maximum temperature of the headers where the exhaust gas hits them cannot be raised above the BTU value of the escaping exhaust gas.
But headers don't only have just the surface that faces the exhaust valve, the other side of that 1/8th inch thick piece of tube sits in a nice cold airstream (assuming you're not stuck in traffic). This cooling air is constantly wicking away heat from the headers.
By wrapping the headers and starving them of cooling air the exterior of the headers does indeed run hotter, causing the mean temperature of the header to be higher than an unwrapped set of headers.
So mikejpss, next time you want to show off your community college degree in BS, keep it to yourself and don't try to show off by arguing about something nobody said, or cares about.
Old Jun 22, 2011 | 07:39 PM
eagle275's Avatar
eagle275
got my headers coated, plus sprayed Lizard Skin under car, in engine bay, inside the car, and using a mat insulator inside also.
http://www.lizardskin.com/car-insula...lications.html
Old Jun 23, 2011 | 10:13 AM
KevinK's Avatar
KevinK
Hahahaha. This thread just gets better and better! I agree with Golden here, and I believe that is the point of the wrap. It keeps that temp on the header, not spreading to the rest of the motor.
My closing argument?
Header coatings FTW.
Old Jun 23, 2011 | 02:06 PM
  #33
Imo Apita's Avatar
Imo Apita
What we haven't mentioned yet is that header wrap can retain moisture and this may accelerate the rusting process from the outside.
Usually exhaust rusts from the inside as moist air is drawn I'm after engine shutdown and moisture condensates. Ever seen am exhaust pipe drip water after start up on a cool morning?
Old Jun 23, 2011 | 04:24 PM
  #34
Wrecked82's Avatar
Wrecked82
In case it makes any difference, I have decided to not do header wrap.
Old Jun 23, 2011 | 04:25 PM
  #35
KevinK's Avatar
KevinK
Heh...my car blows water out like it's a hose. It's parked next to the house, and the pipes dump out the side in front of the rear wheels, and every time I start it when it's been cool out, it splatters the side of the house with condensation.
Old Jun 23, 2011 | 04:28 PM
  #36
KevinK's Avatar
KevinK
I think this is one of those debates that'll never end. Kinda like displacement vs forced induction. Or import vs domestic.
Wrapping has it's pros. And it's cons.
Not wrapping has it's pros. And it's cons.
Old Jun 23, 2011 | 06:15 PM
  #37
Golden's Avatar
Golden
I'm still waiting for the rocket scientist to come along with another pearl of wisdom.
He seems to be avoiding this thread.........
To Instead of header wrap...
Old Jun 23, 2011 | 08:31 PM
  #38
scottyp99's Avatar
scottyp99
I have heard that using header wrap will make you sterile. Is this true?
Scott
Old Jun 24, 2011 | 02:25 PM
  #39
Golden's Avatar
Golden
I've also heard that a roll of header wrap was the 2nd shooter on the grassy knoll
Old Jun 24, 2011 | 02:38 PM
  #40
V8Ranger's Avatar
V8Ranger
Default Header wrap
Maybe Sea Foam could save headers from the savages of the wrap...
