Where are all of the fuses located in a 73 vette? (or at least the major ones). I am a new owner and just trying to figure everything out. I have a book, but this is not addressed. For example, my radio is not working anymore and I want to know where to look. Thanks for any help.
Up under your driver side dash above the foot rest behind the parking brake pedal. It is hard to see. You have to lay on your back and look up, then if you are like me, you can barely see what fuses are for what.
Here's a pix from my 71', your 73' should be the same. The radio fuse is blocked by the harness in this photo, but it is the 10Amp that says TCS Sol on the right. Not sure if you have a TCS system in 73'
