Brake line question
Old Jun 21, 2011 | 10:22 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Brake line question
I'm getting ready to replace my old rubber brake lines with stainless steel lines. The kit is well marked for front/rear and have the new c-clips and two crush washers. My question concerns the crush washers. Are they for the front or rear? I have not removed my old lines yet to answer the question for myself. I have the fittings soaking in PB-Blaster so I don't break anything. I thought I would come here first before I started so I would have everything in place. If they mount up front, do they go on the caliper end or the hard line end? If they mount on the rear, which end?
Thanks as always for any and all help.
Old Jun 21, 2011 | 10:32 PM
wombvette's Avatar
wombvette
front
Old Jun 22, 2011 | 05:30 AM
briaineo's Avatar
briaineo
caliper end, you'll see when you remove the old lines.
you'll need a flare wrench set to do the job..
Old Jun 22, 2011 | 08:55 AM
Tally Ho's Avatar
Tally Ho
Thanks all. I suspected front at the caliper end but wanted to make sure before I started. This forum always comes through for me. I appreciate the help.
To Brake line question
