Backup lights
Old Jun 22, 2011 | 04:07 AM
Iron_dog's Avatar
Iron_dog
Default Backup lights
Hello, I've a 74 model, is it possible to disassembly the backup lights in order to paint, from inside, the red ring of the light? I need it because I have converted the light to the european turn light in yellow and when the light is on it also illuminates the red ring. Thank you
Old Jun 22, 2011 | 09:43 AM
Timsride's Avatar
Timsride
Im not sure that I am totally clear on what you mean but you should be able to just remove the two screws that hold the lens on and remove the lens. Hope this helps.
Old Jun 22, 2011 | 10:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Aren't the 74 lamps sealed units? I don't think they come apart.
Old Jun 22, 2011 | 10:55 AM
Iron_dog's Avatar
Iron_dog
That's the problem! Is there any way to open them OR find any after market lamps that I can open???
To Backup lights
