Radiator hoses
Old Jun 22, 2011 | 06:25 PM
whaler97's Avatar
whaler97
Default Radiator hoses for Champion Radiator Install
I just got an aluminum 3 row radiator from Champion for my 79. The inlet on the upper hose measures about 1.340" dia. I can't find a hose that will fit. Has anyone else had this problem? Most hoses are 1.5". I also have a 1 9/16 end on the thermostat housing on my Performer RPM intake manifold. The radiator I took out had a 1 9/16" inlet port. The hose I had was 1 9/16" throughout. We may have changed a few things when we put the 400 cu. in. block in, but now I have a little problem. Any help would be appreciated. I know, I should have bought American, but I am on a small budget.
Old Jun 22, 2011 | 06:53 PM
Paul L's Avatar
Paul L
That's one-third of an inch. Did you make a typing error?
Old Jun 22, 2011 | 10:21 PM
gbvette62's Avatar
gbvette62
.340" dia.?????????
79 Corvettes used 2 different radiators. The earlier one was used from late 76, till sometime in 79, and had a 1 1/2" inlet. The second design was used from late 79 through 82 and had a 1 1/4" inlet.
Old Jun 23, 2011 | 11:01 AM
whaler97's Avatar
whaler97
I did measure right with a dial caliper. I told the dealer I got the Champion from that 79's only had the two size inputs. That 1.340 must be the Chinese equivalent! The radiator must have been changed when the engine was put in. Is there any way to identify the radiator, stamped numbers, tag, etc? Can I put a smaller hose inside the end of the original 1 9/16" hose on the car? I think I should just send the radiator back for a refund! Are there hose adaptors to accomodate the two sizes? I have the hose I took off and it is 1 9/16 throughout.
Old Jun 23, 2011 | 01:30 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
he means, 1.340"
USE ... "The second design was used from late 79 through 82 and had a 1 1/4" inlet."
Old Jun 23, 2011 | 01:46 PM
Paul L's Avatar
Paul L
Originally Posted by 69Vett
he means, 1.340"
That makes more sense.
Old Jun 23, 2011 | 04:00 PM
whaler97's Avatar
whaler97
Would it be possible to put a piece of the smaller diameter hose inside the end of the 1 9/16 hose to fit the 1.340 inlet on the Champion Radiator? The dealer I bought it from said he has a fab shop in the area that would put a 1 9/16 inlet on for $75.
Old Jun 23, 2011 | 07:00 PM
whaler97's Avatar
whaler97
Default Antifreeze
I was told I should use Zerex G-05 in the aluminum radiator. Is it ok to just drain the old from the radiator and hoses and fill with new or do you need to drain everything in the block too? If so, how is the best way to do that?
Old Jun 24, 2011 | 03:49 PM
whaler97's Avatar
whaler97
Job done, found sleeve for end of hose and all hooked up and running.
To Radiator hoses
