Control Arm Bolts Backwards? - pic
Old Jun 22, 2011 | 08:40 PM
C6DuffMan's Avatar
C6DuffMan
Default Control Arm Bolts Backwards? - pic
Bubba's killing me. These upper control arm bolts are backwards aren't they? (71 Coupe BB) Are they special bolts? What keeps the bolt from spinning (assuming it's installed correctly). This is giving my alignment guy fits. He said it was very hard to get to the nut. I don't doubt it. And all four are like this.
Old Jun 22, 2011 | 08:54 PM
Shark Racer's Avatar
Shark Racer
Yup, backwards.
Old Jun 23, 2011 | 12:18 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Backwards from mine too. Allegedly, mine were oem when I researched them before disassembly.
Old Jun 23, 2011 | 12:23 AM
...Roger...'s Avatar
...Roger...
Removing the bolt makes it a lot easier to remove the arm,sure ticks off the alignment guy though.
Old Jun 23, 2011 | 05:19 AM
mrvette's Avatar
mrvette
I do my own alignments, and so have never had a issue with the bolts serrated edge being stripped in the chassis, I just stick a wrench or socket on it, and twist the nut....woopie doo....
in fact if I had a welding capability, I would weld the nutz on the inside of the frame, and make the above 'reverse' position a permanent fix for a silly problem, having to remove the fan shroud, or drive the bolt out to get the control arm off for the pesky UCB's...
Old Jun 23, 2011 | 10:18 AM
69 Chevy's Avatar
69 Chevy
Yes.
There are serrations under the bolt head just like a wheel stud.
To Control Arm Bolts Backwards? - pic
