removing axle from the differential
Old Jun 23, 2011 | 03:22 PM
vette.mix's Avatar
vette.mix
Default removing axle from the differential
My son is working on a 1980 and is having a problem removing the axle from the differential, does he have to drop the differential?
Old Jun 23, 2011 | 03:38 PM
bashcraft's Avatar
bashcraft
You need to remove back cover and then remove the c-clip that holds the axle in.
Old Jun 23, 2011 | 04:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The chassis service manual would be a big help to your son.
Old Jun 23, 2011 | 07:20 PM
SH-60B's Avatar
SH-60B
The back cover is also the mount, so yes, you have to drop the diff.
To removing axle from the differential
