What's this wire??
Old Jun 24, 2011 | 04:26 PM
BruceWGale's Avatar
BruceWGale
5th Gear
Default What's this wire??
There are 4 wires coming out of the bottom, driver's side of the distributor of my 1981 'Vette. They go to a connector that feeds them into the wiring harness on that side of the car. I just bought the car and noticed that the connector was unplugged. I'd like to know what it is before I plug it back in. Any ideas??
Thanks to all,
Bruce
Old Jun 24, 2011 | 04:48 PM
...Roger...'s Avatar
...Roger...
Sounds like the one you disconnect to set timing.
Old Jun 24, 2011 | 05:03 PM
BruceWGale's Avatar
BruceWGale
5th Gear
Default I'm not so sure
I've looked at pictures on this forum for setting the timing and I don't think its that connector. This one has 4 wires.
Old Jun 24, 2011 | 10:10 PM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
It sounds like the dist. on my 82. Those wires are the trigger/sensor for the fuel injection, they tie into the computer. Did you or someone change the dist.? Is there the matching plug in your harness?
Old Jun 25, 2011 | 07:51 AM
BruceWGale's Avatar
BruceWGale
5th Gear
Default Sounds probable
Yes there is a matching plug on the harness. I just wanted to know what it was before I plugged it back in. I wonder why it was disconnected?
Old Jun 25, 2011 | 08:39 AM
...Roger...
Hey, I have an idea,maybe someone was setting the timing and forgot to plug it back in.
Old Jun 25, 2011 | 01:21 PM
BruceWGale's Avatar
BruceWGale
5th Gear
Default We have a problem, Houston!!
I plugged it back in; the engine fired but didn't start. Then I saw a bit of smoke near the air cleaner so unplugged the connector. Now it won't even fire when I try to start it. Damn!!!!
Any ideas??
UPDATE: I disconnected the battery, hoping that it would reset any electronics. After reconnecting, it started. I wonder what the hell happened when I plugged in the connector!!!
To What's this wire??
