Spark plug socket problem solver
Old Jun 24, 2011 | 07:33 PM
69 Chevy's Avatar
69 Chevy
Default Spark plug socket problem solver
Sometimes you just have to take matters in your own hands. And I finally did and should have done sooner.
I couldn't find a short enough 13/16" sparkplug socket to clear the headers on my mouse motor. So I modified an old Bonney Forge socket to suit my needs. First, I removed the foam porcelain protector from inside. Then I marked the outside where I wanted to make the cut to separate the plug end from the wrench end.
See how much wasted space there is?
I used a whizzer to make the cut...nothing fancy.
Then I chucked both ends in my lathe and faced off ~3/8" total.
I changed tooling to put a 45* bevel for MIG welding.
I clamped them and welded with .030" ER70S6 wire, because that's what was in my machine.
Back onto the lathe to cut the weldment flush and re-install the foam packing.
You can see how much longer the Snap-On socket on top is.
One custom socket and one wrench gets to all 8 plugs.
That was an easy 1 hour project!
Old Jun 24, 2011 | 07:51 PM
Shark Racer's Avatar
Shark Racer
Awesome! Wish I had the skill and tools to do that.
Old Jun 25, 2011 | 05:29 AM
Golden's Avatar
Golden
I've had great success with this high tech piece of equipment
Old Jun 25, 2011 | 08:47 AM
imariver's Avatar
imariver
Nothing fancy huh...............
Old Jun 25, 2011 | 09:47 AM
boatdoc's Avatar
boatdoc
Offset box wrenches are my best freind in the boat world!!
Old Jun 25, 2011 | 09:50 AM
Paul L's Avatar
Paul L
Nicely done! I wish that I had those skills.
Old Jun 25, 2011 | 06:44 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
looks good!!!
Old Jun 25, 2011 | 08:25 PM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
So 69 Chevy.......
When do you start mass producing these for the rest of us????????
Nice work btw .......
I love to see a creative mind at work.
When I was a line mechanic eons ago, I swore the "engineers" designing the cars never turned a wrench in their life.
Bman
Old Jun 25, 2011 | 11:55 PM
SteveG75's Avatar
SteveG75
SLP Short Socket $29.95 at Summit
http://www.summitracing.com/parts/SLE-30102/
Old Jun 26, 2011 | 08:01 AM
69 Chevy's Avatar
69 Chevy
I could be persuaded to make more, if it would make life easier for other wrench turners. PM me with your needs.
1. This is not a 13/16" plug socket.
2. I don't like the idea of having the porcelain exposed. I'd rather have it nestled securely inside closed-cell foam.
Only certain styles of sparkplug sockets are good candidates for this modification. If the square hole is NOT broached completely through, it will interfere with the porcelain when cut to the desired length.
Old Jun 26, 2011 | 09:09 AM
tonyv123's Avatar
tonyv123
Very Nice!
I too wish I had the tools to make things I have to buy.
I don't, so I use these:
http://www.summitracing.com/parts/PO...1150/?rtype=10
They also come in 13/16".
http://www.summitracing.com/parts/POW-POW301155/
Kinda pricy, but work very well.
Old Jun 26, 2011 | 03:48 PM
G-Sting's Avatar
G-Sting
Originally Posted by bmans vette
So 69 Chevy.......
Very nice work!
To Spark plug socket problem solver
