82 Cross Fire problems
Old Jun 27, 2011 | 03:47 PM
Carlos Tamayo's Avatar
Carlos Tamayo
1st Gear
Default 82 Cross Fire problems
My 82 is not getting fuel to the injectors consistantly.
I replaced:
ECM
New fuel pump
new fuel filter
new fuel relay
new injectors
Started right up, ran fine for 20 minutes. I shut it off and would not start after that.
No fuel through the injectors.
Next day, fired right up. Ran for 20 minutes.
Now it won't start. No fuel through the injectors.
Fuel pump sounds to be working fine.
Any one have an idea of what to do or how to check this problem out?
Thanks all,
Carlos
Old Jun 27, 2011 | 09:44 PM
terry82's Avatar
terry82
when your car does not start again ,i would check to see if you are getting spark.pull no 1 plug and plug it in to a extra spark plug.if that is good .check for power at the fuel pump .if that is running and you dont have the injectors spraying check the connections .you can get a little light called a noid to tell you if they are getting a signal to spray.
