BB p/s pulley questions, concerns
Old Apr 24, 2002 | 03:39 PM
Bob Turner's Avatar
Bob Turner
Default BB p/s pulley questions, concerns
I paid $84.00 for the dual groove pulley for my BB swap from Paragon. They have it labeled as being a pulley that you have to "press on" vs. just bolting it on.
I am confused, however, since I read in a Zip catalog that the '63-'74 pumps are "bolt on", and the '75-'82 pumps have "press on" pulleys. And '74 was the last year of a BB in a Corvette...
Since I have a '74, I don't understand why that BB pulley has to be "pressed" on since it is a '74 pump. I wonder what the deal with Paragon is. :confused:
I am wondering if I will have to buy a '75 and up pump.....:confused:
Any thoughts on this? :confused:
Bob :confused:
Old Apr 24, 2002 | 03:42 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: BB p/s pulley questions, concerns (Bob Turner)
My 75 was also pressed on but there is a 3/8th threaded hole in the middle of the shaft. I just used a bolt and washer to draw the old pulley back onto the new pump. I held the pulley and wrenched the press fit old pulley on.
Old Apr 24, 2002 | 03:44 PM
Jeff73454's Avatar
Jeff73454
Cruise-In III Veteran
My 73 is bolt on. Your 74 should be too! Send it back and get the right one.
Old Apr 24, 2002 | 06:42 PM
Jim Shea's Avatar
Jim Shea
I'm looking at the 2002 Paragon catalog. All the cast iron pulleys are listed as BB w/tapered shaft and lock nut 65-74. Maybe you are looking at an old catalog with a mistake in it.
To BB p/s pulley questions, concerns
