choke and battery light staying on
Old Jun 29, 2011 | 07:07 PM
c4rookie's Avatar
c4rookie
3rd Gear
Default choke and battery light staying on
Hi I'm new here. just bought a 1981 c3. last week the choke light and batter light came on and stayed on. The engine was running high idle and hot. After searching a few forums I learned that it might be a bad alt. So I had it checked and it was not working. I replaced it and everything was in working order. Now today the same thing happend as I was pulling it into a shop bay to have wheels balanced. Started it up and choke/batter lights stayed on. They checked the alt and it was putting out 19 volt and checked the battery while car was running and only 12 there. Could use some help in this area please.
MIke
Old Jun 29, 2011 | 07:56 PM
kf4cln's Avatar
kf4cln
i had same problem recently, mine was the exciter wires going from harness to alt.Autozone has a pigtail , so I replace it and troubles went away.
Good luck
Rob
Old Jun 30, 2011 | 08:50 AM
c4rookie's Avatar
c4rookie
3rd Gear
what are the exciter wires from the harness to the alt?
Old Jun 30, 2011 | 09:36 AM
TimAT's Avatar
TimAT
Check the choke fuse and relay.
Old Jun 30, 2011 | 10:37 AM
c4rookie's Avatar
c4rookie
3rd Gear
can you tell me where the choke fuze and relay are located?
Old Jun 30, 2011 | 12:09 PM
TimAT's Avatar
TimAT
The choke heater fuse is in the fuse block- left of the steering column on the firewall. Here's a link to a wiring diagram:
http://www.nrjvette.com/johdotukset/?c=d;o=d
I like to print them as big as I can, then align all the wires, tape together and track the system I'm working with a highlighter.
IIRC, the choke relay is under the hood to the right of the distributor. (memory- may not be correct)
Get a 12v testlight, and check the brown wire that plugs into the alternator for power with the key on.
To choke and battery light staying on
