speed-o-meter stopped working
Old Jun 29, 2011 | 08:09 PM
mcmsmsc's Avatar
mcmsmsc
Default speed-o-meter stopped working
wondering where to start looking. on my way home my speed-o-meter stopped working. the odometer and trip meter are still operational. where should i check first?
thanks
Old Jun 29, 2011 | 08:29 PM
scottyp99's Avatar
scottyp99
My first thought was speedo cable, but as I read further, and you say the odometer still works, then that means the cable is still functional. Something is wrong with the speedo itself. That's all I have for ya, maybe somebody else can elaborate.
Scott
Old Jun 29, 2011 | 10:58 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
For the odometer to be turning the first worm is turning...
This tells me something is either binding up the speed cup or the needle is bent and hitting the face.
There is a jewel bushing in the front that could have come loose but you'd be hearing noise if this were the case. If you look at the jewel plate you'll see the little brass cup bushing below.
Really this is just the opposite of what the problems usually are.
Do you hear any noise?
Old Jun 30, 2011 | 05:10 AM
mcmsmsc's Avatar
mcmsmsc
the car is a 1977 i forgot to mention.
no i did not hear any noise. was driving down the highway and the speedometer bounced a couple times then slowly went to zero.
Old Jun 30, 2011 | 08:58 AM
0Willcox Corvette
Former Vendor
It has to be something wrong with either the speed cup or the needle.
The cable direct drives the first worm and magnet (A).
For the odometer to work, the first worm has to be turning.
The speed cup has a spindle through it that the needle is pressed on to. This spindle also comes out the bottom and floats in the bushing in the end of (1)
You said bounced... all the way to the right? The speedo may have slammed the needle and bent it. This could happen if the first worm bushing was wearing out. To explain this a little further, the first worm bushing in most cases is the culprit of speedometer failure. If the bushing gets enough play in it the first worm which normally magnetically drives the speed cup actually ***** enough to touch it. When this happens it can slam the needle and sometimes it will bend or break it off.
Still I'm not sure what the problem is, but the speedo will need to come out.
Old Jun 30, 2011 | 05:26 PM
mcmsmsc's Avatar
mcmsmsc
the bounce was a 5mph flux. not a major slam to one side. then slowly went to zero. do yu think this is something that i can repair? or a shop? or will i have to replace it?
thanks
Old Jun 30, 2011 | 06:33 PM
mcmsmsc's Avatar
mcmsmsc
how big of a job is it to get the speedo out and apart?
Old Jun 30, 2011 | 11:57 PM
0Willcox Corvette
Former Vendor
thanks
You can not do this repair at home, I'm sorry you'd need to send it in.
I have detailed instructions on our site on how to remove the lh dash pad to get to the speedometer.
Corvette Left Hand Dash Pad Removal Made Easy 1968-1977
http://willcoxcorvette.com/repairand...lp.php?hID=318
Old Jul 1, 2011 | 02:23 AM
eastltd's Avatar
eastltd
Please pm me wth your contact info. I would like to send mine out for repairs first. I've had it out 7 tmes, so I can get in the mail before the op.
Old Jul 1, 2011 | 08:23 AM
mcmsmsc's Avatar
mcmsmsc
Do you have contact info to where I would send it for repair? Thanks for responding and helping out. Greatly appreciated.
Old Jul 1, 2011 | 10:59 AM
0Willcox Corvette
Former Vendor
you can send it to:
Willcox Inc. c/o Service Dept.
123 E. Maple Street
Jeffersonville, Indiana 47130
Old Jul 1, 2011 | 03:51 PM
mcmsmsc's Avatar
mcmsmsc
thanks again. will send it in when i get it out
Old Jul 1, 2011 | 09:58 PM
0Willcox Corvette
Former Vendor
No problem... and thank you!
To speed-o-meter stopped working
