Ok been reading old post and googling the heck out of it, but I like to be sure. I want to convert my 77 too manual steering. My other cars are manual and I have no problem with it. All my PS stuff is leaking all over and I'm just looking for the cheap/quick way to get it done. Plus I plan on drag racing some and wouldn't mine the tad weight loss or acceleration gain.
I've read about the spindle holes and mine is a 77 so I only got one set. So replace the control valve with the Borgeson unit and what else?
Been trying to reading about the piston thingy or damper, stabilizer. Well all I can say is, there's one on it. Do I need it? Is manual one different?
Thx for the help, woulkd like to hear from anyone who has done this convert.
send a PM if you or anyone else is interested in owning a genuine GM HD manual steering center link (relay rod/drag link) and the correct pittman arm in bolt on condition.
Just bought a manual drag link and pitman arm from redvetracr myself (showed up in the mail yesterday). He's a stand up guy, and you don't get any easier than the stock setup.
The C2 and C3 Corvettes with manual steering had a steering damper until sometime late in the 1968 model year. (The damper was cancelled in the 1968 AIM on April 20, 1968.) For engineering and/or cost reduction reasons, it was determined that it was no longer required. I have information that the damper was never used on big block Corvettes.
Now, the basic Corvette chassis didn't really change from 1963 through 1982. So what changed around 1968 that might have allowed the damper to be removed? Well probably nothing major. Possibly tire changes? Maybe something changed in the late 60s but removing the damper was never investigated at that time.
Steering dampers were used on many manual steering vehicles throughout the years.
Power steering fluid acts as a damper in vehicles with hydraulic power assisted steering.
didn`t the Corvette get wider wheels and larger front spindles in 1969? and didn`t the damper go away when the relay rod got thicker?
From: Graceland in a Not Correctly Restored Stingray
That would seem a logical path things might well have followed to this viewer.
BTW, what diameter are those HD relay rods you've got? I'd like to compare that with the one I got from Dick G back in the day, as the topic came to mind during one of Günther's threads recently.
Hello sir. I'm switching my 79 vette to manual steering and was wondering if you might have the parts needed. and a price. thanks
