Front Brakes
Old Jul 1, 2011 | 06:47 PM
Jeff Kessler's Avatar
Jeff Kessler
6th Gear
Default Front Brakes Need Help
Best way to replace front caliper Have a rebuilt oring caliper ready to go. All help will be appreciated TIA Jeff K Have a great 4th.
Old Jul 2, 2011 | 07:06 AM
69small block's Avatar
69small block
Default brakes
there are 2 5/8bolts on the back of caliper take these out caliper will come right off you might consider new rubber lines also while your doing this also take hose from caliper while its on car easier to work it reinstall new calipers bleed the lines and your good to go
Old Jul 2, 2011 | 08:38 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
when workijng on brakes and/or suspension: always replace like parts both sides… In other words never replace just one caliper!!!!
Old Jul 2, 2011 | 09:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the chassis service manual.
Old Jul 2, 2011 | 09:42 AM
McDuffieclan's Avatar
McDuffieclan
Cruising
Funny, I just did this and completed it this week. 69Smallblock is dead on. Remove the two bolts and the calipers slide right off, Do replace the rubber hoses as stated, they run about 9 bucks a peice do not forget the clips to hold the upper portion of the hose in place. They are about a buck.
When putting the calipers back on, I slid the shoes in place, losen the bleeder screw a tad and squeezing them open is a cinch.
Old Jul 2, 2011 | 09:55 AM
...Roger...'s Avatar
...Roger...
Be very careful when removing the hose from where it mounts to the frame,if you round the metal brake line fitting it will ruin your day.
Here is an alternative IF you are planning to use the car this weekend. You can spin the caliper off the brake hose and spin it back on so as to not open up a can of worms.
Sometimes this will work and sometimes it won't,be careful with cross-threading and hose winding.
Replacing the hose is the best way to go.
To Front Brakes
