Slip yoke question
Old Jul 2, 2011 | 06:55 PM
Dante7's Avatar
Dante7
Default Slip yoke question
Not a vette question but hopefully it should apply.. I have a M22 in my 69 chevelle that I have been chasing a driveline vibration in since I purchased it. The car has a brand new m22 the slip yoke seems to be loose in the tranny it has play up and down and side to side in the yoke. When I compared to the yoke in the vette's turbo 400 which was rock solid. So I marked the yoke with the car sitting on the wheels and then pulled the driveshaft. The barrel on my yoke is only 3 3/4 inches long with 1 inch outside of the tranny and only 2 3/4 inches in the tranny itself... It appears that the yoke could be almost 5 inches long before it got anywhere near where the speedo gear is. If I slide the yoke in about 3/4 of an inch it gets a lot more tight and has very little play. it does not appear to show any wear so is the yoke I have to short if so how long shoudl it be?
Old Jul 2, 2011 | 07:41 PM
redvetracr's Avatar
redvetracr
the barrel (shaft) on a 31 spline Corvette yoke is 3-1/2", it should stick out of the trans (give or take) 3/4". sounds like your rear bushing is worn.
