Upgrading to HEI - Firing Order
Old Jul 3, 2011 | 06:25 PM
cruisin68's Avatar
cruisin68
Default Upgrading to HEI - Firing Order
Ok. I'm just finished a build on my 68 327 and have added an HEI wirh tach drive. Looking at my Haynes manual there are two sets of firing orders....one for a v8 with points style distributor and one for the HEI distributor years.
My Question: Should i be concerned with the HEI firing order just because I upgraded to HEI or do I stick with the original firing order from my old points distributor?
Just need to add gas after this and see if she starts....
As a side note I am providing 12V to new distributor from the fuse box ING..any problems with that? Tracing the resistance wire for the old coil is like looking at needle in a hay stack.
Old Jul 3, 2011 | 06:37 PM
...Roger...'s Avatar
...Roger...
Old Jul 3, 2011 | 06:40 PM
scottyp99's Avatar
scottyp99
Not really sure what you're talking about. Small block chevy firing order is 18436572.
Scott
Old Jul 3, 2011 | 06:44 PM
cruisin68's Avatar
cruisin68
Scott
That's what I thought. Must be a misprint on this edition the other listed with HEI reverses the 7 an d 6 cylinders.
Odd.
Thanks for keeping my sanity
Old Jul 3, 2011 | 07:10 PM
scottyp99's Avatar
scottyp99
Odd.
The LS engines have a different firing order, maybe some info got mixed up somewhere. Odd, indeed.
Scott
Old Jul 3, 2011 | 07:22 PM
Gordonm's Avatar
Gordonm
SB firing order is 18436572
LS firing order is 18436752
Old Jul 4, 2011 | 09:04 AM
pawpaws toy's Avatar
pawpaws toy
The firing order doesn't change. But on the HEI cap #1 cyl starts 1 position off from the points cap. The chilton manual shows this a little better. Happy 4-th!!!
Old Jul 4, 2011 | 09:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Must be a misprint...
FWIW: don't take everything in the Haynes as gospel.
To Upgrading to HEI - Firing Order
