69-72 guys with BB, refresh my memory
Old Jul 5, 2011 | 01:35 AM
LT1driver's Avatar
LT1driver
Default 69-72 guys with BB, refresh my memory
does the bb in the 69-72 wtih power brakes have/need the valve cover with the slanted rear corner?? I can't remember what mine had back in the day(1973) thanks
Old Jul 5, 2011 | 02:52 AM
RickyBerg's Avatar
RickyBerg
I say NO they dont.
But that propably depend on the height of the valvcovers you have.
If you have a look in my photos you can se my 454 with ansen covers that fits togheter with the powerbrakes without any problems.
http://forums.corvetteforum.com/gara...RickyBerg.html
They are so much higher than the original steel covers that they easily works with roller rockers.
//Ricky.
Old Jul 5, 2011 | 04:33 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Does it have it, Yes.
Does it need it? It's a tight fit, but you can weasel the normal short valve covers w/o the PB booster indent into place.
Old Jul 5, 2011 | 05:30 PM
joewill's Avatar
joewill
don't know about 69, but the 70-72 ncrs tech info and judging guide says that there is an indentation to clear the power brake booster on the drivers side. it doesn't specifiy if or if not this is true if the car has or does not have power brakes. i expect tonawanda didn't know if the car would have power brakes when the engine was assembled so they all had a indent.
so to answer your question, it does have the indentation, does it need it? I don't know.
this is inconsistant from what I have observed, I used to own a 70 BB non power brakes, that i am pretty sure had original covers , and they were not slanted..
but THE BOOK says they should be...
Old Jul 5, 2011 | 06:39 PM
Big Block 69's Avatar
Big Block 69
Mine has power brakes and where the indentation is has nothing to do with the brake booster. Although I have read that the dent is there for Corvettes with Power Brakes.
Old Jul 5, 2011 | 07:11 PM
Roughrider's Avatar
Roughrider
My '69 L71 has plenty of clearance between the booster and valve cover. While I haven't tried it, I don't think taller valve covers would have a problem either.
The C2 big blocks needed the dented valve cover on the left side...not an issue for C3's. That doesn't mean some C3's didn't receive dented valve covers...some certainly may have.
Old Jul 5, 2011 | 07:12 PM
oldsarge's Avatar
oldsarge
To be correct, I believe they had the indent, but as others have said, they will fit without the dent.
Old Jul 5, 2011 | 07:16 PM
TimAT's Avatar
TimAT
My 69 BB does not have a "dented" cover. It is a bit tight getting it in and out, but it does clear fine. Maybe later ones used a larger diameter PB booster?
To 69-72 guys with BB, refresh my memory
