454 front pulley
Old Jul 5, 2011 | 07:01 PM
ellsworthclassics's Avatar
ellsworthclassics
3rd Gear
Default 454 front pulley
have installed a 454 bbc in my 1970. engine is not a covette engine but is a passinger car high performance block. front pulley is resting on crossmember with 1/2" left to go to drop down on motor mounts. pulley is a threegroove with rear groove not used. middle for p/s. outside for alt.. pulley is approx. 7 7/8" by 3" deep. what is the best solution-- is a smaller pulley avl. or do i need to cut a groove in cross member?? gary
Old Jul 5, 2011 | 08:58 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you need BB 3-groove "Corvette pulley" if you use A/C.
that will fit within the crossmember.
Please don't cut the crossmember !
Old Jul 5, 2011 | 09:03 PM
myk7's Avatar
myk7
My stock ac, ps, 71 BB car has a 2 groove pulley that measures a little less than 2 inches. It looks like it has room for another groove though, before it would hit the frame.
Old Jul 5, 2011 | 10:36 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
You will need all vette specific pulleys or cut the cross member,
Sounds like your motor is equipped with a long water pump and pulleys
All C3 vettes came with short water pumps and pulleys to match.
All that being said I cut my cross member and built a larger notch for clearance of a deep crank pulley. Not a big deal to do if you have minor fab skills.
Neal
Old Jul 6, 2011 | 07:03 AM
CFD E59's Avatar
CFD E59
It's a tight fit... Get the Corvette specific pulley's.
Old Jul 6, 2011 | 10:26 AM
crf311's Avatar
crf311
Anyone have the correct part number for the corvette BBC pully?
Old Jul 6, 2011 | 11:16 AM
Ironcross's Avatar
Ironcross
no part number, not sure there is one...but with HIGH heat on the cross member you can make a substancial dimple it to fit without losing any strength and look like nothing happened.......no cuts ect.
Old Jul 6, 2011 | 01:25 PM
tonyv123's Avatar
tonyv123
If this isn't the one you need, these people probably have the one's you need:
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Looks like Zips web site is down right now, when it's back up search, 454 pulley
Old Jul 6, 2011 | 06:54 PM
blively's Avatar
blively
subscribing to this thread... having the same issues.. but im now on the hunt for vette pullys lol
Old Jul 6, 2011 | 09:32 PM
BBCorv70's Avatar
BBCorv70
According to the Assembly Manual, the part number for the crank pulley, LS5 454 is 3921923.
Water pump pulley #3889372.
The manual states these pulleys were used with RPO C60 as well, 454 with AC.
To 454 front pulley
