camshaft war!!
Old Apr 25, 2002 | 03:58 AM
szercer's Avatar
szercer
Default camshaft war!!
Ok, not really, but it's hard decision for me here, my chioces are A)$255 comp cams k cam kit that comes with camshaft, lifters, timing chains/gears, valve springs, spring retainers and locks, valve seals+$17 mr gasket gasket kit... or B)$78 crane cam energizer cam and lifters+$60? valve springs(I don't know which sizes though), $53 mr gasket gasket and timing chain set... now the latter is obviously cheaper but do I need those retainers/seals/locks, and is the comp cams 260h worth the extra dough, or would I be better getting the timing chain seperate, some say they'll add some hp...
Old Apr 25, 2002 | 07:31 AM
1979toy's Avatar
1979toy
Default Re: camshaft war!! (szercer)
I bought a Comp XE262 cam and lifter kit a few months ago. Had the same questions. I decided that I could pick the springs and timing gear myself. Looking back on it I think that I would get the spring recommended by Comp. rather than another brand. For my timing chain I got a double row Cloyes. Either will last as long as I'm going to drive the car and one will not work noticeably better than the other.
Old Apr 25, 2002 | 10:05 AM
ZD75blue's Avatar
ZD75blue
Default Re: camshaft war!! (1979toy)
ow... i got shafted :jester
I wish i could be more of a help.... but i am shooting for 350 horsepower, thinking port and polish heads intake and exahst manifolds. An xe 256 or 268h cam... crossing fingers to hit the magic number
Old Apr 25, 2002 | 10:20 AM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
1979TOY...........have been considering the XE262 , for my big/block....hows the low end / mid range tourque ? what the redline ?.. ... I am sticking with 308 rear gears for my 66 driver ...want a 6000 rpm redline & good tourque...was also considering , 278 comp cam high energy .....my cam is stock 390 hp 427 Chevy , I shift at 5600 RPM, last year tuned 13.7 @ 102 MPH ....any info appreciated :) :seeya
Old Apr 25, 2002 | 01:42 PM
1979toy's Avatar
1979toy
Default Re: camshaft war!! (StrayDog)
StrayDog-
I'm using a G-Tech to check my 0 to 60 times and only do one shift. The engine seems to prefer to go to 5200 RPM. Higher RPM = slower 0-60. Lower RPM= slightly slower 0-60. Running the engine to 4500 RPM and shifting makes faster speeds than running it to 5800. These numbers have not been fully firmed up as I'm doing carb. adjustments with every pass so the end result may be differant yet.
Don't know how, if at all, this will relate to a big block.
Old Apr 25, 2002 | 02:08 PM
adam's Avatar
adam
Get someone to dyno the two cams - then you'll know the difference if any.
I've looked at these two possibilities too - wondered what the differences
were in the engine.
Which cam's were you looking at ? 260? 268? 10172 (crane?)
Old Apr 25, 2002 | 02:09 PM
Justin79-L-82's Avatar
Justin79-L-82
I just ordered the comp cam xe 262 K-kit... damn expensive but it comes with everything you need... I'd stick to the kit because everything works together and if you go mixing and mathcing parts up it might not work as well as it should
Old Apr 25, 2002 | 02:52 PM
szercer's Avatar
szercer
Default Re: camshaft war!! (adam)
I'm thinking of the 260 crane or comp cams, I like the low end torque
Old Apr 25, 2002 | 10:23 PM
tnt76vette's Avatar
tnt76vette
I like the 260H by CompCams.....Its all done by 5200 rpm......isnt that enuff for the street? :D :D :D
To camshaft war!!
