ID Quadrajet Carb?
Old Jul 6, 2011 | 05:40 PM
AR71Stingray's Avatar
AR71Stingray
Cruising
Default ID Quadrajet Carb?
Hello. I am in the middle of converting to power brakes and need to identify the Quadrajet currently on my 1971 350 4-speed convertible. The number is 17054923 followed by 2089.
I need the power brake booster line that connects to rear-bottom of the Quadrajet. The threaded fitting for a 1971-73 is too large. Maybe if I can identify the carb, I can locate a fitting.
Thanks for any help.
Old Jul 6, 2011 | 06:34 PM
Rich's'78's Avatar
Rich's'78
The 170xxx is for a 1975 or newer carb. Primary needles are not interchangable with a 70xxx carb, which is what you should have.
Old Jul 6, 2011 | 06:56 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Default some info for you....
hope this helps....
17054923 GMC SERV REPL 71 350 ALL
Main Jet - 74
Main Rod - 39
Spring - 7036019
Sec. Rod - BA
The correct carb for your Vette is: 7041213
Old Jul 6, 2011 | 11:01 PM
myk7's Avatar
myk7
17054923 GMC SERV REPL 71 350 ALL 74 39 7036019 BA 3.1062 3.7699
Sounds like it's for a 71 GMC truck, 350
You can probably get an adapter fitting.
http://corvetteparts.com/item/fittin...ter-1973-1981/
Old Jul 7, 2011 | 12:02 AM
AR71Stingray
Cruising
Much thanks! The adapter fitting looks like it is exactly what I need.
Old Jul 7, 2011 | 12:16 AM
myk7's Avatar
myk7
Cool deal.. you might be able to get one at a local auto parts store.
To ID Quadrajet Carb?
